RUMLogNG version 2.11
What's new?
  • Fixed: RUMlog toggles PTT for Fldigi, while Fldigi in in Tune mode - Tnx Jwahar, KC1CCR
  • New: Callsign auto complete function in the Paper QSL In window
  • New: In the separate Map window, you can add a grid square overlay
  • New: In HamQTH.com or qrz.com found postal addresses can be used for address label printing - See Menu-->QSL
  • New: Satellite list updated
  • New: For the grid square you can save now up to 10 digits
  • New: The local time zone can be used instead of utc, see Preferences-->General-->Logbook behavior
  • New: QSO Note field can be prefilled with data from a previous QSO: Preferences-->Databases-->Fill entry fields with data from previous QSOs
  • New: European HF Championship
  • New: RDA Contest
  • New: YO DX HF Contest
  • New: KCJ Contest
  • New: WAEDC CW/SSB/RTTY - including QTC traffic
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
For printing (English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
Add a grid square overlay to the maps
ct1drb
Re: RUMLogNG version 2.11
Unread post by ct1drb »
Hello Tom,
tks for your new RUMLogNG version 2.11,
Map with grid squares is indeed a wonderful idea. What misses now is a map with worked and confirmed grid squares.
Best 73 and tks for all.
CT1DRB
David Quental
David, you can get it:
  • Go to Menu-->Window-->Search QSOs
  • Press the button Expert Search
  • Enter this to to get all worked grids:
      locator <> '' group by substr(locator,1,4)
  • Press the Search button
  • Mark all QSOs in the table (select the table and press cmd A)
  • Go to Menu-->QSO-->Show selected stations on map
To show all confirmed grids on 6m enter
band = '6m'  and (qsl = 'R' or qsl = 'X'  or qsl = 'G'  or lotwqsl = 'X') and locator <> '' group by substr(locator,1,4)
The needles show one station per grid, not the center
ct1drb
Hello Tom,
tks indeed for your instructions, now it is much and much better.
It is a must, at least to me, to see confirmed and worked grid squares.
Again tks a lot and best 73.
CT1DRB
David Quental
K6LE
Unread post by K6LE »
I see in the notes for 2.11 it says we can use 10 digits for the grid locator.
How can this be set to display only 6 or 4?
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
There are no options to set. It is just allowed to enter up to 10 digits into the logging field.
K6LE
OK, well, in the Information window it automatically fills it in with 10 digits and that is transferred to the Log QSO field. . At least that's how it works in 2.12.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
You don't like this?
K6LE
DL2RUM wrote:You don't like this?
I certainly don't need 10 digits. 6 or even 4 is fine with me.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
I will ad an option to limit the number of digits for data take over.
Will this be sufficient for you?
Loc.tiff
Options are. No limit, 6 digits or 4 digits
Loc.tiff (24.84 KiB) Viewed 15141 times
