Posts: 3137 Joined: Mon 27. Aug 2007, 13:36
Unread post
by DL2RUM » Mon 25. Jul 2016, 16:08
What's new?
Fixed: RUMlog toggles PTT for Fldigi, while Fldigi in in Tune mode - Tnx Jwahar, KC1CCR
New: Callsign auto complete function in the Paper QSL In window
New: In the separate Map window, you can add a grid square overlay
New: In HamQTH.com or qrz.com found postal addresses can be used for address label printing - See Menu-->QSL
New: Satellite list updated
New: For the grid square you can save now up to 10 digits
New: The local time zone can be used instead of utc, see Preferences-->General-->Logbook behavior
New: QSO Note field can be prefilled with data from a previous QSO: Preferences-->Databases-->Fill entry fields with data from previous QSOs
New: European HF Championship
New: RDA Contest
New: YO DX HF Contest
New: KCJ Contest
New: WAEDC CW/SSB/RTTY - including QTC traffic
Available in the App Store:
https://itunes.apple.com/app/rumlogng/id964454561?mt=12
Download the latest version here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
English manual:
http://dl2rum.de/RUMlogNG/docs/en/
German manual:
http://dl2rum.de/RUMlogNG/docs/de/
For printing (English, ca. 25Mb):
http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (German, ca. 26Mb):
http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
Add a grid square overlay to the maps
ct1drb
Posts: 36 Joined: Sat 28. May 2016, 09:19
Unread post
by ct1drb » Mon 25. Jul 2016, 18:52
Hello Tom,
tks for your new RUMLogNG version 2.11,
Map with grid squares is indeed a wonderful idea. What misses now is a map with worked and confirmed grid squares.
Best 73 and tks for all.
CT1DRB
David Quental
Unread post
by DL2RUM » Wed 27. Jul 2016, 11:43
David, you can get it:
Go to Menu-->Window-->Search QSOs
Press the button Expert Search
Enter this to to get all worked grids:Code: Select all
locator <> '' group by substr(locator,1,4)
Press the Search button
Mark all QSOs in the table (select the table and press cmd A)
Go to Menu-->QSO-->Show selected stations on map
To show all confirmed grids on 6m enter
band = '6m' and (qsl = 'R' or qsl = 'X' or qsl = 'G' or lotwqsl = 'X') and locator <> '' group by substr(locator,1,4)
The needles show one station per grid, not the center
ct1drb
Unread post
by ct1drb » Wed 27. Jul 2016, 18:25
Hello Tom,
tks indeed for your instructions, now it is much and much better.
It is a must, at least to me, to see confirmed and worked grid squares.
Again tks a lot and best 73.
CT1DRB
David Quental
K6LE
Posts: 142 Joined: Fri 29. Feb 2008, 18:13
Unread post
by K6LE » Sat 17. Sep 2016, 19:52
I see in the notes for 2.11 it says we can use 10 digits for the grid locator.
How can this be set to display only 6 or 4?
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Unread post
by DL2RUM » Sat 17. Sep 2016, 20:31
There are no options to set. It is just allowed to enter up to 10 digits into the logging field.
K6LE
Unread post
by K6LE » Sat 17. Sep 2016, 22:50
OK, well, in the Information window it automatically fills it in with 10 digits and that is transferred to the Log QSO field. . At least that's how it works in 2.12.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Unread post
by DL2RUM » Sun 18. Sep 2016, 03:09
You don't like this?
K6LE
Unread post
by K6LE » Sun 18. Sep 2016, 03:11
DL2RUM wrote: You don't like this?
I certainly don't need 10 digits. 6 or even 4 is fine with me.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Unread post
by DL2RUM » Sun 18. Sep 2016, 14:12
I will ad an option to limit the number of digits for data take over.
Will this be sufficient for you?
Options are. No limit, 6 digits or 4 digits Loc.tiff (24.84 KiB) Viewed 15140 times
