Page 1 of 2
RUMlogNG version 2.5
Posted: Thu 21. Jan 2016, 11:23
- Fixed: QSL Manager was missing in Global QSL ADIF file - Tnx DK5CM
- New: More CW options in the Log Preferences under the CW tab - you have to reset your CW settings
- New: "New one" dx-spots can be notified using Growl
- New: You can remove now a callsign from a band map using cmd mouse click
- New: Separate band map and dx spot windows for the contest module: http://dl2rum.de/RUMlogNG/docs/en/pages ... ntest.html
- New: Memory pad for contest operation
- New: Audio recording and play back functions: http://dl2rum.de/RUMlogNG/docs/en/pages/Audio.html
- New: QSO Export funktion for SOTA database (version 2)
- New: Support for Avery 7163
- New: Introduction of a Contest Cheat database: http://dl2rum.de/RUMlogNG/docs/en/pages/Contest.html
- New: AppleScript support for read/write of State, QSO date & time, the four user fields and for the Use real time checkbox
- New: ARRL Int. DX Contest
- New: CQ WPX contests - CW/SSB/RTTY
- New: PACC Contest
Available in the App Store:
https://itunes.apple.com/de/app/rumlogn ... 4561?mt=12
Download the latest version here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
English manual:
German manual:
http://dl2rum.de/RUMlogNG/docs/de/
Re: RUMlogNG version 2.5
Posted: Thu 21. Jan 2016, 22:09
by ea5xq
Thanks Tom, do you mean that we will not be able to update it from AppStore?
Posted: Fri 22. Jan 2016, 07:18
It will be available in the App Store usually 2 weeks later.
Posted: Sat 23. Jan 2016, 20:40
by nn5ee
I was trying to get cw to work with winkeyer and had to turn key2 line on to get the line connected to key1 to work. Bug?
Posted: Sat 23. Jan 2016, 22:24
When you use a version 1 chip you have to check the out #2 box. The checkbox labels present the version 2 winkey chip. I wasn't aware the differences.
I have to update the docs.
Please confirm, you use a version1 chip.
Posted: Sun 24. Jan 2016, 11:39
The Winkey chip version 1 and 2/3 use different hardware and there are differences in the configuration. The seen settings are applicable for version 2/3 chips. For version 1 read following:
- Side tone enable --> Use pin 5 for sidetone
- Key out 1 enable --> Use pin 5 for key out
- PTT enable --> Use pin 5 for PTT
- Key out 2 enable --> Pin 3 key out enable
Posted: Sun 24. Jan 2016, 19:23
by nn5ee
I have winkey version 23 per flwkey startup response, tnx Billy NN5EE
Posted: Mon 25. Jan 2016, 01:07
by k4zrj
I had the same issue - had to check "key out 2 enable" in order to get the Winkeyer USB (version 3.0) to key the K3.
Thanks for the new features!
73, Charles, K4ZRJ
Posted: Mon 25. Jan 2016, 09:49
Charles, can you connect your trx to the Key 2 jack? Which setting is required to key output 2?
Posted: Mon 25. Jan 2016, 16:15
by K6LE
DL2RUM wrote:Charles, can you connect your trx to the Key 2 jack? Which setting is required to key output 2?
If I plug it in to Key 2 then "Enable Key 1" works.
