ea5xq
Posts: 104 Joined: Fri 11. Apr 2014, 16:45
Unread post
by ea5xq » Thu 21. Jan 2016, 22:09
Thanks Tom, do you mean that we will not be able to update it from AppStore?
Posts: 3139 Joined: Mon 27. Aug 2007, 13:36
Unread post
by DL2RUM » Fri 22. Jan 2016, 07:18
It will be available in the App Store usually 2 weeks later.
nn5ee
Posts: 11 Joined: Mon 9. Feb 2015, 04:47
Unread post
by nn5ee » Sat 23. Jan 2016, 20:40
I was trying to get cw to work with winkeyer and had to turn key2 line on to get the line connected to key1 to work. Bug?
Unread post
by DL2RUM » Sat 23. Jan 2016, 22:24
When you use a version 1 chip you have to check the out #2 box. The checkbox labels present the version 2 winkey chip. I wasn't aware the differences.
I have to update the docs.
Please confirm, you use a version1 chip.
Unread post
by DL2RUM » Sun 24. Jan 2016, 11:39
The Winkey chip version 1 and 2/3 use different hardware and there are differences in the configuration. The seen settings are applicable for version 2/3 chips. For version 1 read following:
Side tone enable --> Use pin 5 for sidetone
Key out 1 enable --> Use pin 5 for key out
PTT enable --> Use pin 5 for PTT
Key out 2 enable --> Pin 3 key out enable
nn5ee
Unread post
by nn5ee » Sun 24. Jan 2016, 19:23
I have winkey version 23 per flwkey startup response, tnx Billy NN5EE
k4zrj
Posts: 27 Joined: Fri 14. Jan 2011, 04:36
Unread post
by k4zrj » Mon 25. Jan 2016, 01:07
I had the same issue - had to check "key out 2 enable" in order to get the Winkeyer USB (version 3.0) to key the K3.
Thanks for the new features!
73, Charles, K4ZRJ
Unread post
by DL2RUM » Mon 25. Jan 2016, 09:49
Charles, can you connect your trx to the Key 2 jack? Which setting is required to key output 2?
K6LE
Posts: 142 Joined: Fri 29. Feb 2008, 18:13
Unread post
by K6LE » Mon 25. Jan 2016, 16:15
DL2RUM wrote: Charles, can you connect your trx to the Key 2 jack? Which setting is required to key output 2?
If I plug it in to Key 2 then "Enable Key 1" works.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
