RUMlogNG version 3.3
What's new?
  • Fixed: Crash when using an older macOS version - Tnx K3URT
  • Fixed: Some functions didn't worked as expected in the IC-7300 Control Window on non Europain systems - Tnx K0PIR
  • Fixed: Refresh of the Sun Window works more reliable now
  • New: TRX control windows: clicking on a frequency read out digit, increments or decrements this digit
  • New: Real time callsign check sheet: Menu-->Contest-->Callsign check sheet
  • New: Map to show worked grid squares in VHF contests: *Menü-->Contest-->Show grid map*
  • New: QSL label Avery 3422 (35 mm x 70 mm at DIN A4 3 x 8)
  • New: Band maps support 60m now (except contest), but no mode recognition
  • New: Transceiver clock setting for the IC-7300 (IC-7300 Ctrl window)
  • New: Changes made for ADIF version 3.0.5, mainly new operating modes
  • New: Wisconsin QSO Party
  • New: Oklahoma QSO Party
  • New: DARC UKW-Sommer-Fieldday
  • New: DARC UKW Frühlingswettbewerb
  • New: DARC VHF-, UHF-, Microwave Contest March
  • New: DARC VHF-, UHF-, Microwave Contest May
  • New: DARC VHF-, UHF-, Microwave Contest June
  • New: DARC VHF-, UHF-, Microwave Contest July
  • New: IARU-Region-1 145 MHz Contest September
  • New: IARU-Region-1 UHF/Microwaves Contest October
  • New: Nordic Activity Contest
Available in the App Stor: https://itunes.apple.com/app/rumlogng/id964454561?mt=12
For printing (Version 2.11 - English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (Version 2.11 - German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
K0PIR
Re: RUMlogNG version 3.3
Unread post by K0PIR »
Set Time on the 7300 is awesome! I like to be able to go back and forth.
Thank you.
Rich, K0PIR
Got SD?
www.K0PIR.us
