RUMlogNG version 2.12
What's new?
  • Fixed: The window Receive Paper QSLs shows the QSOs with the selected colour code now - Tnx Terry, M0CLH
  • Fixed: Entry of a / for a received QTC is possible now - Tnx DL1RF
  • New: Load, view and save eQSL images Menu-->QSL-->Load eQSL image
  • New: Apple Script support for the contest interface
  • New: Use the internal CW keyer in the TS-480 - Tnx DL7VDX
  • New: IC-7300 Control Window: Scope reference level can be saved and restored by band (optional)
  • New: IC-7300 Control Window: Scope fixed edges can be selected matching the actual frequency (optional)
  • New: Open a Contest or Logbook file by double click it or drop a file over the application icon
  • New: Support for label printer format 90mm x 29mm
  • New: If the option Menu-->Logbook-->Show prev. QSOs selected, the logbook will not show any longer an empty table when the station isn't in the log yet
  • New: CAT support for FT-840
  • New: RSGB SSB Field Day
  • New: FOC QSO Party (Please reload the Contest Cheat Database: Menu-->Online-->Load contest cheat Database)
  • New: Africa All Mode International DX Contest
  • New: New England QSO Party
See here how the eQSL image download works: http://dl2rum.de/files/eQSL.mov
See here how the edges selection change works for the IC-7300: http://dl2rum.de/files/Edge.mov
For printing (Version 2.11 - English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (Version 2.11 - German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
m0pkz
Re: RUMlogNG version 2.12
Unread post by m0pkz »
Thank you Tom for updates!!!!!!!!
ct1drb
Unread post by ct1drb »
Hello Tom,
tks for new RumlogNG version.
Best 73.
CT1DRB
David Quental
There is a minor bug in the eQSL image download function.
If you get the error message
Error: You must specify the QSO Date/Time as QSOYear, QSOMonth, QSODay, QSOHour, and QSOMinute
you should change your password and avoid special characters in it. The '#' character made this problem by one of the users. The problem will be fixed in the next RUMlog version.
Tnx Andy, DL7UAW
