Page 1 of 2
RUMLogNG version 2.11
Posted: Mon 25. Jul 2016, 16:08
What's new?
  • Fixed: RUMlog toggles PTT for Fldigi, while Fldigi in in Tune mode - Tnx Jwahar, KC1CCR
  • New: Callsign auto complete function in the Paper QSL In window
  • New: In the separate Map window, you can add a grid square overlay
  • New: In HamQTH.com or qrz.com found postal addresses can be used for address label printing - See Menu-->QSL
  • New: Satellite list updated
  • New: For the grid square you can save now up to 10 digits
  • New: The local time zone can be used instead of utc, see Preferences-->General-->Logbook behavior
  • New: QSO Note field can be prefilled with data from a previous QSO: Preferences-->Databases-->Fill entry fields with data from previous QSOs
  • New: European HF Championship
  • New: RDA Contest
  • New: YO DX HF Contest
  • New: KCJ Contest
  • New: WAEDC CW/SSB/RTTY - including QTC traffic
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
For printing (English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
Add a grid square overlay to the maps
Re: RUMLogNG version 2.11
Posted: Mon 25. Jul 2016, 18:52
by ct1drb
Hello Tom,
tks for your new RUMLogNG version 2.11,
Map with grid squares is indeed a wonderful idea. What misses now is a map with worked and confirmed grid squares.
Best 73 and tks for all.
CT1DRB
David Quental
Posted: Wed 27. Jul 2016, 11:43
David, you can get it:
  • Go to Menu-->Window-->Search QSOs
  • Press the button Expert Search
  • Enter this to to get all worked grids:
      locator <> '' group by substr(locator,1,4)
  • Press the Search button
  • Mark all QSOs in the table (select the table and press cmd A)
  • Go to Menu-->QSO-->Show selected stations on map
To show all confirmed grids on 6m enter
band = '6m'  and (qsl = 'R' or qsl = 'X'  or qsl = 'G'  or lotwqsl = 'X') and locator <> '' group by substr(locator,1,4)
The needles show one station per grid, not the center
Posted: Wed 27. Jul 2016, 18:25
by ct1drb
Hello Tom,
tks indeed for your instructions, now it is much and much better.
It is a must, at least to me, to see confirmed and worked grid squares.
Again tks a lot and best 73.
CT1DRB
David Quental
Posted: Sat 17. Sep 2016, 19:52
by K6LE
I see in the notes for 2.11 it says we can use 10 digits for the grid locator.
How can this be set to display only 6 or 4?
Posted: Sat 17. Sep 2016, 20:31
There are no options to set. It is just allowed to enter up to 10 digits into the logging field.
Posted: Sat 17. Sep 2016, 22:50
by K6LE
OK, well, in the Information window it automatically fills it in with 10 digits and that is transferred to the Log QSO field. . At least that's how it works in 2.12.
Posted: Sun 18. Sep 2016, 03:09
You don't like this?
Posted: Sun 18. Sep 2016, 03:11
by K6LE
DL2RUM wrote:You don't like this?
I certainly don't need 10 digits. 6 or even 4 is fine with me.
Posted: Sun 18. Sep 2016, 14:12
I will ad an option to limit the number of digits for data take over.
Will this be sufficient for you?
Loc.tiff
Options are. No limit, 6 digits or 4 digits
Loc.tiff (24.84 KiB) Viewed 15145 times
