Rumlog and Microkeyer II, Can't make the PTT work
WB0KWJ
Re: Rumlog and Microkeyer II, Can't make the PTT work
Post by WB0KWJ »
Tom:
Thank you for seeing that. CAT for frequency and mode work even with 1000 in that space. I have changed it. CAT is still working. CAT and the keyer always worked. I have also made the Microkeyer work on Windows and Linux. So, other than the USB bug, I think the Microkeyer is OK. Your configuration tool is much easier to use, even for connecting the box to other computers. I would rather use Microkeyer II with RumlogNG.
If you know a method for activating the PTT on the radio that does not involve Auto PTT, I would greatly appreciate it. I cannot figure out the settings to get PTT from the app to the radio. I assume there is a path, even if it is not direct. I have even tried directing the app audio to the radio microphone to use the radio VOX. But the audio stream seems to require an active PTT in the Microkeyer. It is very possible I have missed something.
Thank you again
Jim
WB0KWJ
Post by DL2RUM »
In the microKeyer status panel are a lot of bubbles, one is for PTT. Even on the MKII is a PTT LED. When the PTT LED is lit, software is okay and you have a hardware issue.
Since I'm using a microKeyer by myself, I'm sure it must work. I've tested iDigi with MKIII and dx-lab suite commander successful. iDigi shows the correct frequency and the PTT toggles as well.
WB0KWJ
Post by WB0KWJ »
Tom:
Thank you for the response. I am still on a Microkeyer II. My understanding is that your Microkeyer III uses a newer 24-bit USB audio chip and hardware design that can deal effectively with the Mac's USB negotiation.
I know about the PTT/SC/LINE LEDs and their behavior, the configuration of Auto PTT, and all the many audio routing options. I have made the Microkeyer II work with Linux and Windows. I have even made the AutoPTT work on a Mac with WSJT-X in Parallels, and speak correctly to Rumlog. That is not a solution because the USB integration by Parallels is fragile and cannot be trusted from one time to the next.
I am going to conclude that the audio components and transmitter keying in Microkeyer II cannot be made to work at the same time with RumlogNG. If they can, send me the settings. Something obvious has probably evaded me. I simply want the transmitter to send a signal when I generate it in the digital app--in the same manner as in Windows and Linux.
Thank you again for all the time you devoted to trying to resolve this issue. Thank you for continuing to make RumlogNG ham radio's best logger/controller.
Jim
WB0KWJ
Post by DL2RUM »
I just noticed that you also activated a DX-Lab Commander CAT in the RUMLog UDP tab. You should just use the Server under the TX#1 tab.
WB0KWJ
Post by WB0KWJ »
Tom:
I appreciate all of the assistance so far and the advice on settings. One more question regarding working around the MKII codec bug with RUMLOG.
Do you know if the TRX CAT option in RUMLOG works with the TS-2000?
Here are some details.
When I watch the CAT traffic between RUMLOG and the TS-2000, I see that RUMLOG sends "TX0;" to the radio when it should. "TX0;" is the correct TS-2000 command to turn on the main transmitter.
However, the response to "TX0" from the radio is "?". That says the TS-2000 does not accept the command. "RX;", the correct command to return to receive mode, also produces "?" from the TS-2000. All the other CAT commands sent from RUMLOG function as they should.
This suggests that TRX CAT does not work with the TS-2000. The instructions for FLDIGI say that CAT PTT does not work and recommend PTT with RTS.
TRX CAT could solve the MKII codec bug. But it seems not to work. Perhaps you have seen or heard about this.
Thank you again for your attention to this issue and for your assistance.
Jim
WB0KWJ
WB0KWJ
Post by WB0KWJ »
Tom:
I have discovered that "TX0;" does not work with the TS-2000. However, the abbreviated command, "TX;", does key the main transmitter. On the TS-480, "TX;" is a valid command that is read by the radio as "TX0;".
The TS-2000 manual does not list "TX;" as a valid CAT command. This looks like a firmware bug. "RX;" is rejected unless the radio is already in TX mode.
"TX1;" also does not seem to work.
I wrote a helper that intercepts "TX0;" from RUMLOG and substitutes "TX;" going to the radio over TCP serial. Now the main transmitter seems to key as it should using TRX CAT.
"TX;" might only accept audio from the microphone jack, as it does on the TS-480. I have not tested that.
Jim
WB0KWJ
This is my web monitor screen to see CAT activity. The traffic from RUMLOG is very fast, and the web updates are slow, so not everything is always visible. But I can usually catch "TX0;" coming from RUMLOG. My app, which runs on an ESP32C3 in line with the serial stream, substitutes the command "TX;" when it sees "TX0;".
