FLDIGI set up
Jacques
FLDIGI set up
Unread post by Jacques »
Apologies ( maybe age) but I wish to run RTTY on FLDiGI but having issue setting it up and would appreciate any direction / pointers ( move from MS to Mac so not to expert on Mac)
Running IC7300 one usb cable - Rumlog NG and WSJTX all no issues . Apparently FLDIGI can be run straight from RL settings etc. but no success. ( no need FLRIG ??? )
Thank you all
73s Jacques
Mac OS Sequoia 15,7. RL 5.2. WSTX RC3 .1
Best 73s Jacques F1VEV
Re: FLDIGI set up
Jacques
Re: FLDIGI set up
Thank you will investigate but not sure what is the "Enter XML RPC "
OK all good ( had to change port) RL controls FLDIGI etc Thanks
I canot find a FLDIGI forum for Mac but now when trying RTTY CW I have no sound (from TX whne its tansmiting) and nothing is received on the waterfall ?
Jacques
Re: FLDIGI set up
Hello sorry but need more help so far all reading videos etc have made no headway and Fldigi ic 7300 does not work ( aiming for cw and Rtty)
so I have removed FLDIGI from Mac including hidden files etc .
for Rumlog are those 3 screen shots correct ? or do I need to do something else if ok I will proceed with FLDIGI controls
thank you
Re: FLDIGI set up
In Fldigi --> Host you have to enter the tcp/ip address from the machine where Fldigi is running.
Jacques
Re: FLDIGI set up
Capture d’écran 2026-01-31 à 14.18.23.png (26.71 KiB) Viewed 13724 times
Thank you Tom I now have RL controlling FLDIGI from TX can chose mode QRG etc and FLDIGI follows
RTTY appears and tested OK great but still missing something on CW ? for CW do not wish to use the winkeyer but the rig ? some set up required in FLDIGi
Thanks again
Re: FLDIGI set up
For CW use a WinKeyer.
Jacques
Re: FLDIGI set up
no success with winkeyer ( I have WK3). sorry
Jacques
Re: FLDIGI set up
FYI. all up and running now now need to see how to log Fldigi to Rumlog NG. 73
