Posts: 3125 Joined: Mon 27. Aug 2007, 13:36
Unread post
by DL2RUM » Thu 24. Jan 2019, 09:41
RUMlogNG 4.1 is available here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip
Available in the App Store:
https://itunes.apple.com/app/rumlogng/id964454561?mt=12
English manual:
http://dl2rum.de/RUMlogNG/docs/en/
German manual:
http://dl2rum.de/RUMlogNG/docs/de/
What's new?
Fix: Contest Scoreboard Windows don't get any longer the focus - Tnx David, CT1DRB
New: Added a menu entry for HamQTH/qrz.com/CQQRZ Info Window
New: Support qrzcq.com
New: JS8 Mode added (ADIF version 3.0.9)
New: Transceiver support TenTec Omni VII
New: QSO Note field can be added to the SOTA export
New: Contest support for WSJT-X QSOs
New: WSJT-X can overwrite user definable logging fields in the QSO record if applicable (my_gridsquare, time_on, operator, station_callsign)
New: ADIF/ADX Export for special activities (WWFF)
New: Option for the FT-8x7 added to change the mode automatically for voice keyer operation - SSB-DIG-SSB
New: NRAU-BALTIC Contest
New: ES-OPEN HF Championship
New: BARTG Sprint Contest (also used for BARTG Sprint 75 Contest)
New: BARTG HF RTTY Contest
HK3W
Posts: 22 Joined: Wed 29. May 2013, 14:02
Unread post
by HK3W » Thu 24. Jan 2019, 22:05
Hello Today I donload the last version 4.1 and I saw this
Captura de pantalla 2019-01-24 a la(s) 5.03.51 p. m..png (28.66 KiB) Viewed 9154 times
Unread post
by DL2RUM » Thu 24. Jan 2019, 22:53
It's a failure in the Spanish translation- It should read RUMlogNG
AE0BU
Posts: 2 Joined: Tue 29. Jan 2019, 00:05
Unread post
by AE0BU » Tue 29. Jan 2019, 00:33
Are .rlog files from the previous version compatible with 4.1? My QSO list is empty when I load my previous file now.
Unread post
by DL2RUM » Tue 29. Jan 2019, 09:44
AE0BU wrote: Are .rlog files from the previous version compatible with 4.1? My QSO list is empty when I load my previous file now.
Yes, it is. Check the Filter popup menu on the right hand side in the middle.
AE0BU
Unread post
by AE0BU » Tue 29. Jan 2019, 15:32
DL2RUM wrote: AE0BU wrote: Are .rlog files from the previous version compatible with 4.1? My QSO list is empty when I load my previous file now.
Thanks! I realize I had the "This Year" filter set.
W5GD
Posts: 1 Joined: Tue 26. Mar 2019, 02:34
Unread post
by W5GD » Tue 26. Mar 2019, 12:23
Trying to transfer log info to LotW.
When trying to enter the path to the app and data file, the dialog box doesn’t populate. I went to [Preferences] [LotW] to enter my info. The two dialog boxes for the [path] to the app and file bring up a finder window, and get a [Open] option to finish. The box simply closes without filling the path. Additionally, on the [path for data file], the data file is grayed out and not sellectable in the finder window.
Unread post
by DL2RUM » Tue 26. Mar 2019, 12:26
Screen shots please!
