RUMlogNG version 4.1
RUMlogNG 4.1 is available here:
What's new?
  • Fix: Contest Scoreboard Windows don't get any longer the focus - Tnx David, CT1DRB
  • New: Added a menu entry for HamQTH/qrz.com/CQQRZ Info Window
  • New: Support qrzcq.com
  • New: JS8 Mode added (ADIF version 3.0.9)
  • New: Transceiver support TenTec Omni VII
  • New: QSO Note field can be added to the SOTA export
  • New: Contest support for WSJT-X QSOs
  • New: WSJT-X can overwrite user definable logging fields in the QSO record if applicable (my_gridsquare, time_on, operator, station_callsign)
  • New: ADIF/ADX Export for special activities (WWFF)
  • New: Option for the FT-8x7 added to change the mode automatically for voice keyer operation - SSB-DIG-SSB
  • New: NRAU-BALTIC Contest
  • New: ES-OPEN HF Championship
  • New: BARTG Sprint Contest (also used for BARTG Sprint 75 Contest)
  • New: BARTG HF RTTY Contest
HK3W
Re: RUMlogNG version 4.1
Unread post by HK3W »
Hello Today I donload the last version 4.1 and I saw this
Captura de pantalla 2019-01-24 a la(s) 5.03.51 p. m..png (28.66 KiB) Viewed 9151 times
It's a failure in the Spanish translation- It should read RUMlogNG
AE0BU
Unread post by AE0BU »
Are .rlog files from the previous version compatible with 4.1? My QSO list is empty when I load my previous file now.
AE0BU wrote:Are .rlog files from the previous version compatible with 4.1? My QSO list is empty when I load my previous file now.
Yes, it is. Check the Filter popup menu on the right hand side in the middle.
AE0BU
Thanks! I realize I had the "This Year" filter set. :roll:
W5GD
LotW
Unread post by W5GD »
Trying to transfer log info to LotW.
When trying to enter the path to the app and data file, the dialog box doesn’t populate. I went to [Preferences] [LotW] to enter my info. The two dialog boxes for the [path] to the app and file bring up a finder window, and get a [Open] option to finish. The box simply closes without filling the path. Additionally, on the [path for data file], the data file is grayed out and not sellectable in the finder window.
Screen shots please!
