RUMlogNG version 2.5
  • Fixed: QSL Manager was missing in Global QSL ADIF file - Tnx DK5CM
  • New: More CW options in the Log Preferences under the CW tab - you have to reset your CW settings
  • New: "New one" dx-spots can be notified using Growl
  • New: You can remove now a callsign from a band map using cmd mouse click
  • New: Separate band map and dx spot windows for the contest module: http://dl2rum.de/RUMlogNG/docs/en/pages ... ntest.html
  • New: Memory pad for contest operation
  • New: Audio recording and play back functions: http://dl2rum.de/RUMlogNG/docs/en/pages/Audio.html
  • New: QSO Export funktion for SOTA database (version 2)
  • New: Support for Avery 7163
  • New: Introduction of a Contest Cheat database: http://dl2rum.de/RUMlogNG/docs/en/pages/Contest.html
  • New: AppleScript support for read/write of State, QSO date & time, the four user fields and for the Use real time checkbox
  • New: ARRL Int. DX Contest
  • New: CQ WPX contests - CW/SSB/RTTY
  • New: PACC Contest
Available in the App Store: https://itunes.apple.com/de/app/rumlogn ... 4561?mt=12
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
ea5xq
Re: RUMlogNG version 2.5
Unread post by ea5xq »
Thanks Tom, do you mean that we will not be able to update it from AppStore?
73's Juan, EA5XQ
http://www.ea5xq.net
It will be available in the App Store usually 2 weeks later.
nn5ee
Unread post by nn5ee »
I was trying to get cw to work with winkeyer and had to turn key2 line on to get the line connected to key1 to work. Bug?
When you use a version 1 chip you have to check the out #2 box. The checkbox labels present the version 2 winkey chip. I wasn't aware the differences.
I have to update the docs.
Please confirm, you use a version1 chip.
The Winkey chip version 1 and 2/3 use different hardware and there are differences in the configuration. The seen settings are applicable for version 2/3 chips. For version 1 read following:
  • Side tone enable --> Use pin 5 for sidetone
  • Key out 1 enable --> Use pin 5 for key out
  • PTT enable --> Use pin 5 for PTT
  • Key out 2 enable --> Pin 3 key out enable
nn5ee
I have winkey version 23 per flwkey startup response, tnx Billy NN5EE
k4zrj
Unread post by k4zrj »
I had the same issue - had to check "key out 2 enable" in order to get the Winkeyer USB (version 3.0) to key the K3.
Thanks for the new features!
73, Charles, K4ZRJ
Charles, can you connect your trx to the Key 2 jack? Which setting is required to key output 2?
K6LE
Unread post by K6LE »
DL2RUM wrote:Charles, can you connect your trx to the Key 2 jack? Which setting is required to key output 2?
If I plug it in to Key 2 then "Enable Key 1" works.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
