Import contest info
EA1DAV
Import contest info
Unread post by EA1DAV »
After some contest, ARRL DX, CQWW 160 m etc, when i import the data for the log the state/province is loss, or not in the state field in the log program.
I import it in the comments field, and then, manually type the state info.
Is there any way to do this automated ? Any plan to add this function if no possible now ?
Thanks, Jesus.EA1DAV
Re: Import contest info
You are right Jesus, contest exchange information are not used further.
But there is a work around: Select the QSOs in question (in the 'normal' logging window and select Menu-->QSO-->Add QSO data. See the help file: http://dl2rum.de/RUMlogNG/docs/en/pages/HamQTH_qrz.html
EA1DAV
Many thanks by the help. It work and save lot of work, the only problem is that some info in QTH.com is not the one that the stations pass in the contest. But better than nothing :-)
73.
