RUMlogNG version 3.0
What's new?
Due to introducing support for the magic Touch Bar, nearly all parts of the code were touched. There are not much new functions, but due to internal changes the major version number was increased.
The Touch Bar may change the way you work with RUMlog.
  • Fixed: Contest - Callsign check will be performed now after clicking in band map or dx-spot window - Tnx EA3HOE
  • Change: TRX control macros for Elecraft will be stored now per model (K3, KX3, KX2)
  • New: Support for new Touch Bar
  • New: CQ marker in contest band map
  • New: QSL label Avery 3658 (33.8 mm x 64.6 mm auf DIN A4 3 x 8)
  • New: Köln-Aachen Herbstcontest (DARC)
  • New: ARRL Sweepstakes contest
  • New: HA-DX Contest
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
For printing (Version 2.11 - English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (Version 2.11 - German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
rcbenedict1545
Re: RUMlogNG version 3.0
Unread post by rcbenedict1545 »
thanks for ARRL SS Tom, could we have ARRL VHF contest also?
i have a log entry where log was not following radio so freq was incorrect. i corrected freq but now band is wrong and i dont see a way to change it.
Ray
W8LYJ
ea5xq
Unread post by ea5xq »
Congratulations Tom for this new version, just installed and works great!
Nice to see my TouchBar interacting with RUMlogNG.
Just few comments:
1.- With DX Spots just able to see up to 6m, Spots WWV and Ann are hidden
2.- WIth Terminal only 6 buttons appear
73s Juan EA5XQ
73's Juan, EA5XQ
http://www.ea5xq.net
The used dx-cluster touch bars are not user configurable. In the System Preferences I configured the Touch Bar to show application contents only. This gives enough space for all buttons:
ea5xq
You're right
I was playing with the configuration and indeed just with App contents it shows everything. Cool!
73s and tnx
73's Juan, EA5XQ
