RUMlogNG version 3.0
Posted: Sat 26. Nov 2016, 16:28
What's new?
Due to introducing support for the magic Touch Bar, nearly all parts of the code were touched. There are not much new functions, but due to internal changes the major version number was increased.
The Touch Bar may change the way you work with RUMlog.
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
For printing (Version 2.11 - English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (Version 2.11 - German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
- Fixed: Contest - Callsign check will be performed now after clicking in band map or dx-spot window - Tnx EA3HOE
- Change: TRX control macros for Elecraft will be stored now per model (K3, KX3, KX2)
- New: Support for new Touch Bar
- New: CQ marker in contest band map
- New: QSL label Avery 3658 (33.8 mm x 64.6 mm auf DIN A4 3 x 8)
- New: Köln-Aachen Herbstcontest (DARC)
- New: ARRL Sweepstakes contest
- New: HA-DX Contest
