RUMlogNG version 2.13
What's new?
  • Fixed: General Contest: Failure in creating the serial number fixed - Tnx DK1OM
  • New: Option added for Fldigi PTT switching
  • New: Commands added to save all downloaded eQSL images and to close all windows - See Menu-->QSL
  • New: QSOs can be deleted now from the Search QSOs window
  • New: IC-7300 Control: Auto Hold Funktion for the Scope Center Mode: http://dl2rum.de/files/Auto-Hold.mov
  • New: qrz.com queries ignore /P, /M, /AM, /MM and /QRP
  • Neu: Option added to reduce the number of grid square digits in the log after a HamQTH.com or qrz.com query: Preferences-->Databases
  • New: Oceania DX Contest
  • New: Pennsylvania QSO Party
  • New: Russian World Wide Digital Contest
  • New: California QSO Party
  • New: RSGB International DX Contest
  • New: Deutscher Telegraphie-Contest
  • New: UK/EI DX Contest
  • New: The Makrothen Contest
  • New: JARTS WW RTTY CONTEST
  • New: CQ WW DX Contest RTTY
See here how the eQSL image download works: http://dl2rum.de/files/eQSL.mov
See here how the edges selection change works for the IC-7300: http://dl2rum.de/files/Edge.mov
For printing (Version 2.11 - English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (Version 2.11 - German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
Re: RUMlogNG version 2.13
Just seen a bug: Using Sierra, the heading needle is gone. :o
ok3ar
Unread post by ok3ar »
Hi, Tom,
What reason is to ignore /P etc? It would not be like that option? I have had just the opposite problem, many portable station have pages with /P etc. often with actual data ... How it reads info from a "basic" brand.
Can you give an example of a /P station?
I have to think about it again ...
ok3ar
"New: qrz.com queries ignore /P, /M, /AM, /MM and /QRP"
This i am mean... :)
Can you give me an example of a station listed with /P?
ok3ar
Ah, OK :o)
from my head i found
http://www.qrz.com/db/M0MCY/P
http://www.qrz.com/db/SQ9PND/P
me... :) i can found other station from my logbook, if you will. Yes, there are not many of those stations, but if you working portable, is better have a page for other suffixes too (you have another locator, equipment etc.)
If i am starting portable operation, i have only main call page and I had very little QSL. If i am make next "calls" and pages with /P, the QSL was significantly better.
The problem on the portable is, that many stations only download the info from QRZ and push Enter. Then come QSL cards and electronic QSL (LoTW and eQSL) only for "main call"...
You are absolutely right, I have to consider other options.
I was not aware, qrz.com allows this.
va2ss
Unread post by va2ss »
DL2RUM wrote:Just seen a bug: Using Sierra, the heading needle is gone. :o
Same here...
73 de Jeff | VA2SS
LA0FA
Unread post by LA0FA »
I have installed version 2.12. The App Store is offering 2.13 but it is not updating my app - and not offering to update .... Strange ! Matthias
