CAT via applescript
SM0THU
CAT via applescript
Unread post by SM0THU »
What are the plans for extending the applescript support?
Right now I'm getting the frequency via GUI scripting. It works, but it's not an elegant solution :geek:
I also miss the ability to control the PTT that RUMlog has. Also being able to set the transceiver frequency would be great.
73 de Anders - SM0THU
http://jt-bridge.eller.nu
Re: CAT via applescript
Why do you need to trigger the PTT? Why do you want to change the frequency? What are you doing?
SM0THU
I'm trying to connect WSJT-X to the transceiver via RUMlogNG instead of directly. That way RUMlogNG can be connected to the serial port all the time, and no reconfiguration is needed when running WSJT-X.
Oh, sorry I missed that.
What do you need exactly? Maybe you should e-mail me, since this is not for public interest yet.
kf5jra
Unread post by kf5jra »
I am very interested in this functionality. It would be nice to have JT-Bridge interface with RUMlogNG to allow for WSJT-X interface. At quick glance would using the network stack bound to the loopback (127.0.0.1) interface to communicate be the best path to still maintain sandboxing of the RUMlogNG and hopefully not interfere with the acceptance into the Apple store.
From what I can tell Windows is using virtual serial ports and/or Windows DDE for this type of communication/sharing.
Thank you SM0THU for looking into this so quickly. :)
I volunteer to test. :)
-Ron
ea5xq
Unread post by ea5xq »
Just for let you know I am know testing the integration of WSJT-X with RUMLogNG. FOr the time being, directly they are not "good friends" but I will try using JT-Bridge.
Let's keep in touch
Best
Juan, EA5XQ
73's Juan, EA5XQ
http://www.ea5xq.net
kf5jra
Juan,
You responded to a 9 month old post. I think you will enjoy using JT-Bridge to work with wxsjt-x. My info in QRZ is unto date if you need any assistance grab my email from there.
73 de KF5JRA
Ron
ea5xq
Hi Ron,
Yes, it works smoothly, thanks for the support. JT-Bridge is doing a great job with RUMLogNG and WSJT-X. I have got also an applescript to log the QSOs into RUMLogNG ... so great!
Thanks both
73's Juan, EA5XQ
