Will RUMLog run on Lion?
w2nra
Unread post by w2nra »
73, Art, W2NRA
K3DCW
Re: Will RUMLog run on Lion?
Unread post by K3DCW »
Yes.
I picked up one of the new Mac Minis with Lion and the first program I installed was RUMlog. It works just fine.
Dave
K3DCW
Dave
K3DCW
"Hamming it up on macOS"
K6LE
Unread post by K6LE »
Yes, I loaded Lion Wednesday and almost immediately started running RUMlog and it's been just fine.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Just found out, that the LoTW and eQSL user database update routine is not working. This will be fixed soon.
The voice announcements will not work any longer, when you change to a new multilingual voice. :cry:
When you are using the standard voice, the output may be become unreliable. No fix yet.
