RTTY Modem Transmit Problem
AG7AB
Unread post by AG7AB »
I gave the new RTTY internal modem a try and am having a problem with transmitting. I am using AFSK using USB audio codec with my TS-590. The transmission, reception, PTT, and other functions appear to be working correctly, however I think it is not transmitting correctly. After many transmissions with no response, I tried listening to my signal on websdr.org on a second computer. When I feed my browser output into fldigi, it decodes correctly when using the fldigi RTTY modem, but when transmitting using the RL modem, the received text is completely garbled.
Does anyone have this new function working correctly, or are there any known problems? It looks like a nice enhancement to RL and I look forward to getting it working. One other question: I don't see any integration with QSO logging from the RTTY window. Am I missing something there? or maybe a future addition?
Mike
AG7AB
Re: RTTY Modem Transmit Problem
Pending on your setup you should try Reverse for TX. RTTY is used in LSB.
AG7AB
I need to do more testing, but I think that may have fixed it. Is that what the two buttons do on the lower right corner of the RTTY window, under "RTTY Settings"?
Mike
AG7AB
Yes. With TX revers and RX revers you can swap Mark and Space.
AG7AB
Thanks, Tom. It's working now. I'm not very experienced with RTTY so I was afraid it would be something simple like this.
Mike
AG7AB
rcbenedict1545
Unread post by rcbenedict1545 »
Anyone know the settings to use RTTY with K4D. FLDIGI and WSJT-X work
Ray
W8LYJ
