QSO Upload Utility getting info from RL?
Jacques
Unread post by Jacques »
Hello all,
Getting used to Rumlog NG and enjoying it.
I have LOTW uploads working etc just fine. I installed QSO upload utility to be able to load as logged contacts to QRZ.com and HRDlog.net.
I have configured the utility with all passwords upload codes etc . But it's not reading the log and forwarding the QSOs .
Maybe I need to set a UDP somewhere in Rumlog but cannot see where ? IN the utility there is listen to . N1NM and WSJTX but I would prefer it reads the log ?
All help for a rumlog newbie welcomed
73s
Re: QSO Upload Utility getting info from RL?
See the Help file in the Upload Utility.
Jacques
Hi Tom sorry but do not see any help file in the Utility ap?
Jacques
Tom
I went through what I found and from what I can see I need to set it up in Utility listen to UDP N1MM to port 12060 and enable ?
In RL Settings UDP select Ap info and listen to other RL instance in App info put my host on port 12060 ?
tried that but nothing sorry ?
Follow the instructions in the Help file! The text and the screen shot shows exactly which option you have to use.
When it is still not working, post a screen shot of your settings from both apps.
Jacques
sorry Tom but help fie does not mean say much unless there is another help file top right of logbook
this is what I have Thank you
Attached picture from the Help file, do you see the difference?
Jacques
Thank you Tom for you patience the photo shown in you response I do not see in the help file anyway all ok now Thank you
I do not have in databases tab the auto start for the utility ? but that is not a problem
Thanks again
