The idea of having an indicator for stations that are on LoTW is a good one. But, it seems that if the call has the period after it in the DX Spots window it won't transfer up to the log by clicking on it.
I was wondering why some calls didn't transfer properly and then I noticed that the ones that don't have the tiny period after them.
BTW, Spot handles this info by showing those spots in italics.
LoTW Indicator
LoTW Indicator
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: LoTW Indicator
Here it works fine, I can't find an issue. Do you use the latest 4.3.2?
Re: LoTW Indicator
Yes, working fine here this morning too.
Seems like several things got messed up when I tried to use the F5 key for CW. Including not working from the keyboard but sending from the CW control panel.
After a reload of the program things are back to normal. (except still can't send with any "F" keys higher than F4 - I'll just use the control panel for them).
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: LoTW Indicator
Apple recommends not to use the F keys in own applications. When you have configured your system to use the F keys for OS-X (Spaces, Exposé, etc), then these keys are not visible in RUMlog.
Re: LoTW Indicator
I have the "F" keys set to be regular "F" keys instead of special ones and F1-F4 work fine but none above that.
Not a big deal, I'll just use the CW Control panel
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: LoTW Indicator
This is another story, you have also to disable all other short cuts assigned to the other F keys in your system
preferences.
preferences.
