RumLog and Station Master
G7ORH
Unread post by G7ORH »
Is RumLog compatible with Station Master?
Can I send contact details to RumLog via UDP and what settings should I use? I am new to this !!
Shaun
G7ORH
Re: RumLog and Station Master
No
RL can read QSO data N1MM and FlexRadio Software send out. See Preferences-->UDP
G7ORH
Many thanks Tom
G7ORH
Will RumLog forward QSO’s to Station Master via UDP if I set the host address and port for SM in the contact info part of preferences using the N1MM line?
Shaun
The Station Master I know (https://www.microham.com/contents/en-us/d132_SM.html) doesn't have a network connection.
Contact UDP information is distributed wherever you want.
G7ORH
Many thanks, I think there is a new tool on the block -
https://station-master.online/lander/1
Basically a cloud based logging system that has lots of features built in. Not intended to replace loggers but to enhance the view as it were. Runs well on Mac (beta) and rig control works for me anyway.
Shaun
G7ORH
I have received the following address details from the Station Master creator G5STU -
IP ADDRESS: 134.122.108.243
PORT: 5333
Which fields in the RumLog preferences should I populate to broadcast new qso’s to this address??
Many thanks
Shaun
