Is RumLog compatible with Station Master?
Can I send contact details to RumLog via UDP and what settings should I use? I am new to this !!
Shaun
G7ORH
RumLog and Station Master
Re: RumLog and Station Master
NoIs RumLog compatible with Station Master?
RL can read QSO data N1MM and FlexRadio Software send out. See Preferences-->UDPCan I send contact details to RumLog via UDP and what settings should I use? I am new to this !!
Many thanks Tom
Will RumLog forward QSO’s to Station Master via UDP if I set the host address and port for SM in the contact info part of preferences using the N1MM line?
Shaun
Shaun
The Station Master I know (https://www.microham.com/contents/en-us/d132_SM.html) doesn't have a network connection.
Contact UDP information is distributed wherever you want.
Many thanks, I think there is a new tool on the block -
https://station-master.online/lander/1
Basically a cloud based logging system that has lots of features built in. Not intended to replace loggers but to enhance the view as it were. Runs well on Mac (beta) and rig control works for me anyway.
Shaun
Shaun
I have received the following address details from the Station Master creator G5STU -
IP ADDRESS: 134.122.108.243
PORT: 5333
Which fields in the RumLog preferences should I populate to broadcast new qso’s to this address??
Many thanks
Shaun
PORT: 5333
Many thanks
Shaun
