IC9700 and wsjtx problem
golfine
Unread post by golfine »
Any help no frq reading in wsjtx, here are my settings:
I can recive and transmit, but the window clears after transmit
tnx oz1jmn Allan
Re: IC9700 and wsjtx problem
Port 0 is an invalid port numbe. The port setting in RUMlog has to match your port setting in WSJT-X, 7374.
golfine
Tnx alot i miss that
but still same problem:
tnx oz1jmn Allan
13:53:24 [DxLab Cmdr #2] Server port not started: Address already in use
golfine
Tnx Tom
where are DxLab Cmdr #2 starts ? when i start rumlogng solo it give me:
and when i starts icom 9700:
and wsjtx
73 de oz1jmn Allan
Do you have setup another server under the UDP tab?
golfine
Nope:
73 oz1jmn Allan
You don't see that the port 7374 is used twice?
golfine
No i cant see where ?
please help !
