BaudRate for SPID Rot2Prog
LA0FA
Unread post by LA0FA »
Hi, I try to drive SPID Rot2Prog with Rotor, having installed version 1.1.4 (57) and 600 Bd is missing as a setting in Rotor 1.1.4 (57). Rot2Prog is fixed on 600 Bd. Without that I will not be able to use Rotor software, which seems to be a very nice development indeed ! 73 de LA0FA, Matthias
Re: BaudRate for SPID Rot2Prog
Try version 1.2.3 and report: https://dl2rum.de/rotor/Rotor.zip
Do you have an elevation rotor?
LA0FA
Thanks a lot ! I still need to test. Yes I have a RAK and a RAEL (and a RAS) I want to drive from Rot2Prog. I will report back as soon as possible.
Elevation control is not possible yet for the SPID. Haven't had the possibility to test.
