RUMlologNG version 5.3
RUMlogNG 5.3 is available for direct download here:
https://dl2rum.de/RUMlogNG/RUMlogNG.zip
Available in the App Store soon: https://itunes.apple.com/app/rumlogng/id964454561?mt=12
English manual: https://dl2rum.de/RUMlogNG/docs/en/
German manual: https://dl2rum.de/RUMlogNG/docs/de/
What's new?
  • New: Major changes in the Icom control panels (IC-705, IC-7300, IC-7610, IC-9700)
  • New: Tune your trx using the scroll wheel or touch pad in a Icom scope window
N1JM
Re: RUMlologNG version 5.3
Unread post by N1JM »
I hope ICOM updates the 7610 to the new scrolling mode like they did to the others.
RUMlog has the scroll mode still included for the 7610.
LA0FA
Unread post by LA0FA »
In 5.3 suddenly there is no more Dynamic Scope mode any longer for the IC9700 which I use as Transceiver nr 2 .... it is still there for IC7610 which is the transceiver nr 1.
LA0FA
it would be nice if the scroll mode would support moving mode downlink and uplink (satellite mode, specially for QO-100) at the same time.
LA0FA wrote: Fri 5. Mar 2021, 22:56 In 5.3 suddenly there is no more Dynamic Scope mode any longer for the IC9700 which I use as Transceiver nr 2 .... it is still there for IC7610 which is the transceiver nr 1.
When the 7610 gets a similar firmware update, the dynamic mode will be removed also.
LA0FA
Hi, first now understood the point . Apologise .... after upgrading IC-9700 with the newest Firmware with Scroll Mode, the adjustment of RumLog of course makes a lot of sense. Great work ! I still wonder if I miss something wanting to see the up- and downlink moving tracked when using mouse wheel on scope window when in Satellite mode. Is there a feature either in the Transceiver or Rumlog making this possible ? 73 de LA0DA
Good idea. But it seems we can't get the tracking mode (invers, normal, main or sub only) out if the trx using the CAT commands. So it will be very uncomfortable.
Sp5ets
Unread post by Sp5ets »
Hi Tom, is it possible to connect RumLogNG (macOS) with IC705 only via bluetooth ? I paired with computer, but RumlogNG doesn't have that option.
Regards.
Yes, it is.
To connect RL, the Mac must be disconnected first! See the Bluetooth menu. Please note, on macOS it os a standard Serial port connection!
