RUMlogNG version 4.0
RUMlogNG 4 is available here:
RUMlog 4.0 and newer requires macOS 10.13 (High Sierra)
What's new?
The IC-7610 'Auto Discovery' function doesn't work under macOS 10.13 High Sierra!
  • Changed: Alle drawer type panels are now "normal" windows (HamQTH/qrz.com, RTTY, multiplier help) due to missing support in upcoming macOS versions
  • Changed: Manual saving of QSOs from WSJT-X
  • Changed: macOS 10.13 (High Sierra) or newer required
  • Deleted: Growl support removed, due to missing 64bit supoort
  • Deleted: Import of RUMlog Classic logbook files
  • New: Support for Dymo Labelwriter 90mm x 38mm
  • New: Support for label format Avery 3477
  • New: Support "Dark Mode" in Mojave
  • New: DXCC Entity table shows headings and directions
  • New: Data take over from the HamQTH/qrz.com result table to the **Edit QSO** entry mask
  • New: Touchbar support in the IC-7610 control panel
  • New: In WSJT-X saved QSOs can be saved in the Contest log useful for Dx-Peds
  • New: Filter options in the contest DX-Spot window (FT-8 frequencies are fixed)
  • New: FT8 mode recognition for DX-Cluster spots (FT-8 frequencies are fixed
  • New: New ADIF tags <TEN_TEN> and <FISTS> for user definable logging fields
  • New: Optional use of macOS location services whenever the own grid square needs go be entered
  • New: Scope for IC-7610/IC-7300 shows more control options
  • New: Contest Scoreboards
  • New: Level slider in theIC-7300 Control Panel
  • New: DMC RTTY Contest
  • New: Russian translation started - Tnx Vladimir, R2ADU
n0ehx
Re: RUMlogNG version 4.0
Unread post by n0ehx »
Just wanted to say thank you for getting on the "Dark Mode" wagon with Mojave. Rumlog looks absolutely fantastic in dark mode, beautiful. Changes the entire look and feel of it in my opinion.
k4zrj
Unread post by k4zrj »
I agree - super update. Thank you Tom!
Charles, K4ZRJ
Tnx!
I've just uploaded 4.0.1: http://dl2rum.de/RUMlogNG/RUMlogNG.zip
It fixes some problems with audio input devices.
KT5V David
Unread post by KT5V David »
Thanks for the update Tom. When selecting RUMLog- Preferences in 4.0 and clicking on an item, I get the beach ball. Have to force quit to exit the program.
Same in 4.0.1.
Other program functions seems to be fine as I use them.
Running under mac0S High Sierra 10.13.3. mid-2011 mac mini, so no upgrade to Mojave.
Thanks and 73 de David KT5V
Sounds not good David.
I've noticed this too, even under Mojave. I made few changes and my hope was this fixes it.
Do you have it sporadic (like I have had) or always when you open the Preferences?
DL1AKP
mgl. Bug in 4.0.1
Unread post by DL1AKP »
Hallo,
habe folgendes Verhalten festgestellt: Ich gehe in QSL ==> LOTW-Eingang (oder tqsl-Eingang. Dann werden die QSO geladen und angezeigt.
Klicke ich nun auf einen roten Eintrag, wird das entsprechende QSO im Logfenster angezeigt.
Schliesse ich nun das QSL-Eingangs-Fenster, bleibt nur dieses eine QSO im Logfenster erhalten. Der Button rechts, wo ich "Alle QSO" auswählen könnte ist grau, also nicht funktionsfähig.
Ich kann das nur lösen, indem ich ein QSO logge, und danach wieder lösche. Dann werden wieder alle QSO angezeigt, je nachdem was rechts mit dem Button ausgewählt wurde.
macOS 10.14 Mojave
73 de Andy, DL1AKP
OM Andy DL1AKP / AB7VT
QTH Mitteldeutschland
2015 iMac 27" 5K
macOS current version
Re: mgl. Bug in 4.0.1
DL1AKP wrote:Hallo,
Command W
df1hx
Unread post by df1hx »
I refer to issue "beach ball on prefs window", all on MBP Retina, 13", late 2013 / Mojawe 10.14
Installed (Update by App Store) RumLog NG V4.0.1 .
Gave the program a try right after the update looks really nice and i like the "regular" windows for QRZ information much better than those
"dropdowns" in the earlier versions.
I checked the settings, looks all fine, however i got the spinning "beach ball" right after opening the preferences window.
and RumLogNG showed "does not answer/react" in the process overview.
So i killed RumLogNG manually, logged out from my account and logged in again after a few seconds.
Opened RumLogNG again -> OK, opened RumLogNG's prefs from menu -> OK, NO spinning beachball.
Waited about a minute, checked some settings, i.e. for my LotW account, closed prefs window, ended RumLogNG.
Waited about 30 seconds, did procedure described above again, NO spinning beachball when opening
prefs window, all parameters accessible, program reacts normal (no issues during this quick check).
So on my end it looks like logging out and in again did the trick for me, YMMV...
Thanks for a new, nice looking version of RumLogNG, 73s and cheers, thomas [DF1HX]
Thomas Krull df1hx@darc.de
GnuPrivacyGuard: 0x7892102D
I can see the beachball now also from time to time. It's definitely caused by the Phone setting (sound card). I'm working on it.
