These are really good ideas Lee. Before I make this Beta fully public, I want to ask the more advanced contesters to test it first. Some ideas are new for me. Please download the application only and put it into your existing RUMped folder.
http://dl2rum.de/rumsoft/RUMpedApp.zip
1. Auto Populate Bandmap
There is a new option in the "QSO" menu: "Auto Fill Band Map" When this menu item is checked (toggled on), the band map will be filled with each logged QSO. Further, a non worked call will be took over when you type in the call sign and move the VFO away. (500 Hz in SSB, 300 Hz in other modes) The call entry field will be cleared at this time. This saves keystrokes. Nevertheless you have the possibility to add calls to the band map manually, using the QSO menu.
Of course, the above feature will be active only, while in S&P mode. (Search and Punce)
2. Auto CQ
In the preferences I have extended the max. interval to 20 seconds.
Also, you can set the time intervall in the logging window. Just enter the time in seconds into the Call entry field and press Enter. This will allow you to set the time up to 99 seconds. Decimals are possible.
Please note, this interval specifies the time between the cq calls start. This is not the listening time!
3. Stop Auto-CQ mode
This should work as expected. Please report he active field, when it is not working correct.
4. ESM mode
To toggle the ESM mode on or off use 'Menu-->Log-->Enter sends messages'. An indicator in the right lower corner will remind you, when this mode is switched on. To change between 'Running' and 'S&P' mode use 'Menu-->Log-->Search and Pounce' or mouse click the provided indicator in the right lower corner.
To understand what happens in ESM mode, it is recommended to bring the Macro buttons into view using 'Menu-->Log-->Show Macro Buttons'. This will visualize the ESM mode, but it is not required. Using ESM mode make it important to assign the memories correct:
F1: cq
F2: exchange msg
F3: tu msg
F4: my call
F5: his call
F7: QSO b4 msg
F8: number agn msg
When not in ESM mode, RUMped works nearly in the same manner an known. Some notes to discuss:
- When
not in ESM mode, the 'Enter' key will
not start a cq call, since this is a ESM feature
- In ESM mode both 'Enter' keys work in the same way. To log only, use the 'Log QSO' button.
- The Auto CQ is activated by the F1 key, or the F1 button only.
- If you want to work dupes, select the option 'Menu-->Log-->Allow Dupes'
- Screenshot in ESM and running mode
- ESM.tiff (80.45 KiB) Viewed 7583 times
