Issues with QSO upload and details fill.
ES2XLA
Unread post by ES2XLA »
I'm suddenly started to have issues with filling in QSO details. Before when I was filling in callsign and pressing Tab other details were filled with data from QRZ.com automatically. Right now nothing happens.
Figured this out.
Other issue Im having that QSO Upload utility is no more uploading my QSOs to QRZ.com. When I hit enter just nothing happens in utility log view. Last record is this one [20:04:37] Uploads enabled and just it.
Could you please help me out with this issues.
RumLogNG Version: 6.2 (708)
QSO Upload Utility Version 1.3.11 (27)
MacOS: Tahoe 26.2
73!
Jacques
Re: Issues with QSO upload and details fill.
Unread post by Jacques »
Hi are you sure that in QSO Upload you have under QRZ you have entered both your Call and API Key correctly ? Cheers
You can check following
Mac Acess
and UPD for qsouploader
this works great for me
Best 73s Jacques F1VEV
macOS needs sometimes a reset of your privacy settings for the "local network" functions. Toggle this option off and on again.
When this doesn't fix it, post all related settings - from RUMlog the UDP settings and from the Uploader.
ES2XLA
Unfortunately it's still not working. Here are the settings
Screenshot 2026-04-17 at 17.44.57.png (13.62 KiB) Viewed 16000 times
Screenshot 2026-04-17 at 17.45.36.png (10.23 KiB) Viewed 16000 times
What are your intentions? When you want to upload QSOs logged from RUMlog you have to enable the appropriate options.
See the Help for the upload utility.
Jacques
HI see difference in your first post between yours and mine
ES2XLA
DL2RUM wrote: ↑Fri 17. Apr 2026, 15:17 What are your intentions? When you want to upload QSOs logged from RUMlog you have to enable the appropriate options.
My intention is to automatically upload new logged QSO in RumLogNG to qrz.com. On previous mac, I don't remember I was specially configuring something besides api key for qrz.com
Could you point me to the QSO Upload Utility documentation.
Found the documentation, now it's working. Thank's for the help
Menu-->Help-->QSO Upload Utility Help
ES2XLA
DL2RUM wrote: ↑Sun 19. Apr 2026, 17:04
Already found it, just got it out of my mind that there are some additional configurations.
Thank you for your help!
73!
