SeekYou wildcards
PE2V
SeekYou wildcards
Post by PE2V »
Hello Thomas,
I try to use SeekYou with wildcards but I can't get it working. I tried * and % but doesn't work. Are wildcards allowed anyway? If not could that been added?
TNX de Vin PE2V
Re: SeekYou wildcards
Post by DL2RUM »
No, wild cards are not supported.
Which kind (at which place) do you need it?
PE2V
Post by PE2V »
DL2RUM wrote: Mon 10. Nov 2025, 13:32 No, wild cards are not supported.
I try to use it like this:
I need PA, PB, PC, etc.... Dutch prefixes (0-9) for the NTC Prefixes certificate and I created lists for every P prefix for prefixes I still need. Rules in German language: https://pi4ntc.nl/dpa_deutsch/
For example, in the PE list I add:
PE5*
PE7*
PE8*
PE9*
Or PC list:
PC3*
PC5*
PC6*
PC7*
PC8*
PC9*
Is this possible?
Post by DL2RUM »
Try this: https://dl2rum.de/RUMlogNG/SeekYou.zip
You can enter one wildcard *
PE2V
Post by PE2V »
DL2RUM wrote: Mon 10. Nov 2025, 17:48 Try this: https://dl2rum.de/RUMlogNG/SeekYou.zip
Thanks but I can't use this on my macOS Catalina 10.15.7
Post by DL2RUM »
Hmm - 10.15 isn't supported by the compiler any longer. You can try ist, it may work or not: https://dl2rum.de/RUMlogNG/SeekYou_10_15.zip
PE2V
Post by PE2V »
DL2RUM wrote: Mon 10. Nov 2025, 18:10 Hmm - 10.15 isn't supported by the compiler any longer. You can try ist, it may work or not: https://dl2rum.de/RUMlogNG/SeekYou_10_15.zip
Yes, it works... but I put in the PA list only PA8* but other PA stations are displayed (PA3, PA0) and On the PI list there is no PI4 but I see PI4 displayed in SeekYou.
I'll attach 2 two lists
PI.txt
(44 Bytes) Downloaded 32 times
PI.txt
PA.txt
(4 Bytes) Downloaded 32 times
PA.txt
Post by DL2RUM »
It seems I was a little bit short on beer. Try this: https://dl2rum.de/RUMlogNG/SeekYou.zip
PE2V
Post by PE2V »
DL2RUM wrote: Mon 10. Nov 2025, 18:48 It seems I was a little bit short on beer. Try this: https://dl2rum.de/RUMlogNG/SeekYou.zip
Hehe... time for beer. And yes, it is working correct now. To test I made a couple of duplicate lists: one with the missing prefix and the other with the full list. Prefixes appear on the full list, not on the missing list... that is cool!!! Thank you so much.
Have a nice evening...
73 Vin PE2V
