Clublog upload issue
W4kmz
Post by W4kmz »
I’ve had Rumlog set up to upload my QSO's to Clublog, everything was working fine until 2 days ago.
I attempted to upload some new contacts to Clublog and received the following error, “Error: Login rejected from POST variables”. I initially thought the problem was on the Clublog end as I was getting a timeout error when I tried to open the Clublog website directly.
The next day I was able to open the Clublog website and was logged in with my normal password. Upon attempting to upload the QSO's from Rumlog I again received the same error message. I can export the QSO’s to an .adif file and upload that to Clublog directly with no issues.
Does anyone have any suggestions? Thanks.
Re: Clublog upload issue
Post by DL2RUM »
Few users are affected by this problem (currently you are #4). There were no changes in RUMlog in the last 14 month. I can't duplicate this issue here.
Try to use the App password: https://clublog.freshdesk.com/support/s ... passwords-
Furthermore I would like to know:
  • Which macOS version?
  • Which RUMlog version?
  • Do you use your login password or your App password?
  • Do you log in with callsign or with e-mail address?
  • Do you have special characters in your password?
DL8LTD
Post by DL8LTD »
Hi everyone,
I'm getting the same error: something like “Login rejected from POST variables,” and this has been happening since October 2, 2025. That was the last day I was able to upload successfully.
What I've noticed is that new log entries are being entered in RUMLog, and I can see in ClubLog that an attempt to upload/update is obviously starting. So: uploaded queue: 1 log
I'm using my username and password, but I've also tried the APP password and now set a new password—no changes whatsoever.
Which macOS version? = Tahoe 26.0.1
Which RUMlog version? = 5.20 (690)
Do you use your login password or your App password? both
Do you log in with callsign or with e-mail address? Callsign
Do you have special characters in your password? no special characters
Hopefully we could find a solution together.
Post by DL2RUM »
Pse try it with your registered e-mail address.
DL8LTD
Post by DL8LTD »
My solution is as follows:
Username with email address and the app password.
That made it work again.
PE2V
Post by PE2V »
DL8LTD wrote: ↑Sun 5. Oct 2025, 15:34 My solution is as follows:
EDIT:
I can confirm this too! For both iPhone and Imac apps!
On the iMac app I already used my e-mail address but also the error appears. To fix it I had to:
changed login to 'username' -> still error
changed login back to 'e-mailaddress' -> OK!
W4kmz
Post by W4kmz »
DL2RUM wrote: ↑Sun 5. Oct 2025, 13:44 Few users are affected by this problem (currently you are #4). There were no changes in RUMlog in the last 14 month. I can't duplicate this issue here.
Tom, I’m using:
Sequoia 15.6.1
RL 5.19.5
Login password
Callsign
No special characters
After reading the posts here I double checked my settings, my callsign was listed in the Clublog user name box. I changed it to my email address and normal password and it allowed the QSO's to upload. I didn’t change my Clublog settings in Rumlog since my original setup so I really can’t say when or why my callsign was in the Clublog username spot.
I will add an App password to Clublog and use it on my next upload.
g4sjp
Post by g4sjp »
Sequoia 15.7 here. Rumlog 5.20 (690).
Same issue with Clublog for the last few days. My original Clublog settings in Rumlog were callsign and password. I just changed this to email address and same password (Apple generated with special characters).
Now seems to be working okay.
73 Stephen G4SJP
HK3W
Post by HK3W »
Hello Tom
Clublog's real-time synchronization is not working
I've imported ADIF file with new QSOs, but when I tried to upload them to Clublog it says that there is no new QSOs.
Im use this:
MacBook Air M4 (2025)
Which macOS version? TAHOE 26.1
Which RUMlog version? Version 5.20 (690)
Do you use your login password or your App password? I use Clublog App password.
Do you log in with callsign or with e-mail address? I Use E-mail address
Do you have special characters in your password? Not special caracter
Post by DL2RUM »
When you have activated the real time sync feature, there is no need for a manually upload. Check your log in Club Log.
You can always force a second upload by selecting QSOs in question and using the menu command.
