cannot print qsl labels QL 700
Jacques
Unread post by Jacques »
Hi new to RL I wish to set up the print qsl labels to a brother QL 700 with 90X29 mm labels (used before with HRD) I have read and gone through post with out success. The Brother QL700 works well for labels if used independently . Please any help welcomed
Re: cannot print qsl labels QL 700
What is your problem/question?
Jacques
I believe I did all the correct steps as shown in the previous post yet nothing prints . yet if I print a label from the label software (P-Touch ) it works fine..
It appears that what happens is when sending to print is broken between RL and tenQL 700
You should Print to PDF first to see what is going wrong.
Jacques
That made no difference still will not print on QL 700 label printer
printing on to my regular HP printer on A4 I get the qsl data printed ok but on A4 paper
surely someone must use a label printer with rumlog ?
Cheers
Then you haven't selected the correct paper format: https://dl2rum.de/RUMlogNG/docs/en/page ... Print.html
Read the first paragraph very carefully.
Jacques
Hi Tom I appreciate your help but I have read all of this and for a start te menu does not correspond to what I have .
eg Menu–>Edit–>Print Setup is Menu–>Edit–>Print and there I get photo 1. and from there cannot set all borders to 0
if I go menu page set up I get photo 2
found user define and set 0 photo 3
Paper qsl out gives Phot 4
when hit print I get photo 5
but nothing prints
sorry but there is something I don not understand so far this is the only soft that I have not be able to configure the QL700 running a roll of DK 1104 90x29 labels to stick on qsl card
anyway I am off to hospital for a quick operation so will worry about that later
Thank
Photo 3
Photo 3
Photo 2
Photo 2
photo 1
photo 1
Works fine here.
Print.pdf
(26.99 KiB) Downloaded 955 times
Print.pdf
Jacques
hi while waiting to be operated :-( Great I see it works for you but that does not solve my issue I need to see what are you steps Cheers
Jacques
How to print QSL ? on RL 5.19.1 (678)
Hello well no news from anyone so still cannot print labels to QL700 roll or to HP envy on A4 paper or label paper . I have gone through help so many times but there must be something I am missing since the titles shown in Manuel on help does not read the same as on teh soft
e.g. manual Menu–>Edit–>Print Setup . in software its just print and non of the photo example match so at a loss
in qsl setting I have selected Dymo 29x90 when actually using brother DK 11201 labels 29x90 on the QL 700 though I do not see how that can affect the reading etc
so if someone can please walk me though this I would greatly appreciate it, if it can print on the QL 700 fine then I can get some A4 label page for the HP printer but again how to set up etc .
I hope this can be sorted. out I really do not want to look for alternative source
Thank you all
