RUMlogNG Crashing
crabbyonejohn
RUMlogNG Crashing
Unread post by crabbyonejohn »
Running the latest version of MAC OS-14.6.1 and the latest version of RUMlogNG 5.18 on an M1 MAC Mini with 16 GB RAM and it started crashing on launch. It worked fine last night and this afternoon, it is crashing. I use a sync'd log to iCloud for my iPad/iPhone and they are fine, I even installed the iPad app on the MAC Mini and it works but no CAT control. If needed, I can upload a copy of the crash report generated when it crashes.
Any suggestions to get it working again? I resorted to using a (YUK) Windows machine and Log4OM (Even worse than Windows)...
crabbyonejohn
Re: RUMlogNG Crashing
I have narrowed this down to an issue with the DX Cluster connection-If I do not connect to any cluster, RumLogNG is fine. As soon as I connect, I see a stale spot (over 6.5 hours old). I can delete it but when I reopen and connect, it is still there.
It is also happening on my Macbook and I see the exact same behavior. Even trying 1 cluster at a time causes it to crash.
I do see here old dx-spots as well after connecting the cluster. But no crashes. When exactly crashes your system? Crash reports are welcome. Maybe a screen cast could be helpful.
crabbyonejohn
It crashes within a minute and even a few seconds. It is not throwing the crash report screen now but I would be happy to do a remote session. I can do Teams as well and share my screen. FYI-I am in North Carolina-EST.
crabbyonejohn
I tried again this morning and was able to get a crash report.
RumLogNG Crash report.rtf
Crash report
(60.33 KiB) Downloaded 528 times
Crash report
Any others here with this problem?
I'm not very optimistic but please try this: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip and report back.
crabbyonejohn
I tried the test with the same results-attached is the crash log. I also removed all the cluster connections and it recreated the one for Kiel so I turned off auto connect and it doesn't crash but if I enable it, it crashes within a minute. I added a cluster back in and after connecting, it crashed with in a minute. I have a screenshot of my cluster settings included as well.
CLUSTER SETTINGS
CLUSTER SETTINGS
RumLogNG_Crash_2.rtf
(61.86 KiB) Downloaded 524 times
Please list all your open windows in RUMlog.
Do you use Flex- or Expert SDR radio?
crabbyonejohn
No SDR radios. My main home radio is the 991A. I have the Logbook, The WORLD (grayLine), Sun (HamSQL.com), Network Status, Log Station Info (QRZ & HamQTH) along with the terminal and DX Spots window as seen below. This is usually on my second display-the primary has my browser, email, etc open.
Display Layout
Display Layout
Do you use the Dx-Lab-Suite Commander? For what do you need the Flfigi UDP broadcast?
