Is anyone else experiencing an issue using the 'Tab' key to advance past the call sign? I cant 'Tab" to the signal reports.
K7CAN
Mike
MacOS 14.0 Sonoma tabbing issue
Re: MacOS 14.0 Sonoma tabbing issue
Yes, "TAB" works only from frequency fields
Crazy. After program start the tabbing works, shortly later it doesn't. When I compile the code under Sonoma it works as expected.
Seems to be a little bit more complicated. It works as expected in the IDE but fails when running the compiled app.
HI Tab works as planned here through all field Cheers. Jacques F1VEV
Best 73s Jacques F1VEV
Thanks for the fix DL2RUM!! I noticed it yesterday
