MacOS 14.0 Sonoma tabbing issue
K7CAN
Unread post by K7CAN »
Is anyone else experiencing an issue using the 'Tab' key to advance past the call sign? I cant 'Tab" to the signal reports.
K7CAN
Mike
ik2eae
Re: MacOS 14.0 Sonoma tabbing issue
Unread post by ik2eae »
Yes, "TAB" works only from frequency fields
Crazy. After program start the tabbing works, shortly later it doesn't. When I compile the code under Sonoma it works as expected.
Seems to be a little bit more complicated. It works as expected in the IDE but fails when running the compiled app.
Jacques
Unread post by Jacques »
HI Tab works as planned here through all field Cheers. Jacques F1VEV
Best 73s Jacques F1VEV
K7CAN
Thanks for the fix DL2RUM!! I noticed it yesterday
