QSO to QRZ upload
Jacques
QSO to QRZ upload
Unread post by Jacques »
Apologies for another new user question: I searched the forum but unsure.
Do I need to get QSO Upload in order to be able to upload to QRZ.com ? while LoTW clublog etc is done from main software
73s Jacques
Best 73s Jacques F1VEV
Re: QSO to QRZ upload
Yes
iz6fxs
Unread post by iz6fxs »
It seems that my QSO are all uploaded doubled... Where am I doing wrong. It also applies for HRD log, club log ecc... Thanks!
Check your network UDP broadcast settings.
iz6fxs
Can you spot the misconfiguration?
Thanks!
Norm
Not yet.
But i have seen this before, when you are connected twice. Via LAN and via WLAN.
iz6fxs
It is very much possible on the iMac. As you may know, disabling WiFi is going to stop Airdrop and maybe other things from working... Do you have a suggestion?
Pull the plug. Or try localhost instead of broadcast it to the whole network.
iz6fxs
Thanks, it worked! But I'd think in adding interface selection in preferences ;)
