WSJT-X integration on Ventura broken
LA0FA
Unread post by LA0FA »
After upgrade to Ventura the integration from WSJTX/JTDX to RumLogNG is not working anymore. I see the UDP packages correctly sent (have checked with JTBridge) - using port 2237 ... verified many times that parameters in RumLogNG are correct. One observation : the WSJTX Checked in message/status in RumlogMG's Network Status is missing. Obviously WSJTX has lost the contact with RunLogNG. Any idea how to find the error ?
Re: WSJT-X integration on Ventura broken
It must be a local problem on your side. What have you set as USD Server in WSJT-X? I've seen sometimes trouble when set to localhost.
LA0FA
LA0FA
Problem solved: writing localhost instead of 127.0.0.1 in wsjtx and jtdx actually solved the problem.
Me and others made the same observation, it's not Ventura specific. Maybe a network specialist can explain it.
k4jh
Unread post by k4jh »
I wonder if this is an IPv6 issue, where using 'localhost' resolves to the IPv6 loopback address instead of IPv4 in cases where it's not working.
