Colour scheme
Upload Format
I changed the board settings, you can now upload files with the extension xml, txt or plist.
Blue.xml
(850 Bytes) Downloaded 583 times
Blue.xml
Original.plist
(802 Bytes) Downloaded 592 times
Original.plist
DG5MMQ
Re: Colour scheme
Unread post by DG5MMQ »
Here are the settings from the colours some posting before
have fun
DG5MMQ
MMQ.xml
Greenblue-art
(953 Bytes) Downloaded 642 times
MMQ.xml
Greenblue-art
Re: Colour scheme
Okay,
here the next version to test. I added some selections for text colours.
Colours for list headers, popup- or pulldown menus and some other texts are not changeable. These are fixed and controlled by the operating system.
http://dl2rum.de/rumsoft/RUMlogToTest.zip
BTW, there is now a native K3 support. If you use a K3, you should reselect your TRX settings. Digital modes will be correct assigned now.
g0vgs
Re: Colour scheme
Unread post by g0vgs »
Great work Tom thanks. Thanks for the K3 as well :) Could you add the heading indicator and the large 'Logging Mode' text to the colour options please?
Many many thanks
73 Ian
Ian J Maude | G0VGS
K3s #10268
Re: Colour scheme
Here we are...
Options were added for the bearing pointer and the logger mode info text.
g0vgs
Re: Colour scheme
I changes the Logging Mode colour but it still looked Green until I restarted RUMlog Tom. 4.2 Beta 4.
73 Ian
Ian J Maude | G0VGS
K3s #10268
g0vgs
Re: Colour scheme
Latest Bluegray theme. I will be doing some more over the week.
73 Ian
BlueGrey.xml
(1.51 KiB) Downloaded 599 times
BlueGrey.xml
Ian J Maude | G0VGS
K3s #10268
Re: Colour scheme
I've forgotten the life update, it will be fixed in the next update. BTW, it's not required to restart, just bring the log in the Search or Edit mode, or just press the Escape key and the changes will become active.
DG5MMQ
Re: Colour scheme
some minor updates to the scheme
bluegreen.xml
blue-green
(1.33 KiB) Downloaded 620 times
bluegreen.xml
blue-green
