Colour scheme
Upload Format
I changed the board settings, you can now upload files with the extension xml, txt or plist.
- Attachments
- Blue.xml
- (850 Bytes) Downloaded 579 times
Blue.xml- (850 Bytes) Downloaded 579 times
- Original.plist
- (802 Bytes) Downloaded 587 times
Original.plist- (802 Bytes) Downloaded 587 times
Re: Colour scheme
Okay,
here the next version to test. I added some selections for text colours.
Colours for list headers, popup- or pulldown menus and some other texts are not changeable. These are fixed and controlled by the operating system.
BTW, there is now a native K3 support. If you use a K3, you should reselect your TRX settings. Digital modes will be correct assigned now.
Re: Colour scheme
Great work Tom thanks. Thanks for the K3 as well
Could you add the heading indicator and the large 'Logging Mode' text to the colour options please?
Many many thanks
73 Ian
Many many thanks
73 Ian
Ian J Maude | G0VGS
K3s #10268
K3s #10268
Re: Colour scheme
Here we are...
Options were added for the bearing pointer and the logger mode info text.
Re: Colour scheme
I changes the Logging Mode colour but it still looked Green until I restarted RUMlog Tom. 4.2 Beta 4.
73 Ian
73 Ian
Ian J Maude | G0VGS
K3s #10268
K3s #10268
Re: Colour scheme
Latest Bluegray theme. I will be doing some more over the week.
73 Ian
73 Ian
- Attachments
- BlueGrey.xml
- (1.51 KiB) Downloaded 592 times
BlueGrey.xml- (1.51 KiB) Downloaded 592 times
Ian J Maude | G0VGS
K3s #10268
K3s #10268
Re: Colour scheme
I've forgotten the life update, it will be fixed in the next update. BTW, it's not required to restart, just bring the log in the Search or Edit mode, or just press the Escape key and the changes will become active.I changes the Logging Mode colour but it still looked Green until I restarted RUMlog Tom. 4.2 Beta 4.
Re: Colour scheme
some minor updates to the scheme
- Attachments
- bluegreen.xml
- blue-green
- (1.33 KiB) Downloaded 616 times
bluegreen.xml- blue-green
