Big Sur Update Broke RumlogNG for me
Re: Big Sur Update Broke RumlogNG for me
Try this please: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (at least build 444)
When it still crashes, I have to make some more changes.
K9QJS
Unread post by K9QJS »
Thanks for the version to test. Yes, it fails, when I click on the RumLogNG screen in the "Name" field. Failed this way two times. I did have successful FT8 QSOs when I did not change the screen focus to RumLogNG with this test version. Yesterday, in the previous version, I worked 10 FT8 QSOs with no crash. I have not yet moved my data file out of Dropbox.
So, there is a workaround for me: to not select the RumLogNG window with my mouse while using WSJT-X. Easy enough.
73, Hoop
RUMLOGNG_K9QJS_2020-11-19-1519.rtf
(109.58 KiB) Downloaded 408 times
Here a new try: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (at least build 446)
I removed some third party code which caused the crash. On the down side, few settings are not compatible with earlier versions. You have to set it again:
  • In all Icom and Elecraft Control Panels:
    • Saved to file Memories
    • Saved to file Band Stacking Registers
    • Saved to file Fixed Scope Band Edges
  • List of your preset Dx Clusters
  • Your dx-cluster colours setting (contest & logging)
When this version crashes again, pse provide the crash log.
K9QJS
Tom - No crashes during 5 WSJT-X QSOs, doing the same user activities that I did before which pretty consistently had resulted in crashes every time. I'll do more tests later today and tomorrow and will advise. Looking good so far. Danke schon, 73 Hoop
K9QJS
I did a few more QSOs today. No crashes. Working FB. 73 Hoop K9QJS
