Try this please: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (at least build 444)
When it still crashes, I have to make some more changes.
Big Sur Update Broke RumlogNG for me
Re: Big Sur Update Broke RumlogNG for me
Thanks for the version to test. Yes, it fails, when I click on the RumLogNG screen in the "Name" field. Failed this way two times. I did have successful FT8 QSOs when I did not change the screen focus to RumLogNG with this test version. Yesterday, in the previous version, I worked 10 FT8 QSOs with no crash. I have not yet moved my data file out of Dropbox.
So, there is a workaround for me: to not select the RumLogNG window with my mouse while using WSJT-X. Easy enough.
73, Hoop
73, Hoop
- Attachments
- RUMLOGNG_K9QJS_2020-11-19-1519.rtf
- (109.58 KiB) Downloaded 365 times
Here a new try: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (at least build 446)
I removed some third party code which caused the crash. On the down side, few settings are not compatible with earlier versions. You have to set it again:
When this version crashes again, pse provide the crash log.
- In all Icom and Elecraft Control Panels:
- Saved to file Memories
- Saved to file Band Stacking Registers
- Saved to file Fixed Scope Band Edges
- List of your preset Dx Clusters
- Your dx-cluster colours setting (contest & logging)
Tom - No crashes during 5 WSJT-X QSOs, doing the same user activities that I did before which pretty consistently had resulted in crashes every time. I'll do more tests later today and tomorrow and will advise. Looking good so far. Danke schon, 73 Hoop
I did a few more QSOs today. No crashes. Working FB. 73 Hoop K9QJS
