Contest window won't send CW on TS-590SG
n2iw
Unread post by n2iw »
I'm using RumLogNG 4.3.2 (currently latest version) with TS-590SG using a single USB cable. CAT and CW (through USB) in CW window both work fine! However, when I created a contest, I can't send any CW there. I didn't see any settings for CW when creating contest. Any suggestions will be appreciated, thanks!
Ming (James) N2IW
Re: Contest window won't send CW on TS-590SG
The CW settings for the contest module can be found in Menu-->Contest-->Contest Preferences-->CW.
See this: https://dl2rum.de/RUMlogNG/docs/en/pages/Contest.html
n2iw
Thanks a lot Tom, it works perfectly now!
