RUMlogNG version 4.3
RUMlogNG 4.3 is available here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip
The News list is quite short this time, but I spent a lot of time for works under the hood to improve the performance.
What's new?
  • New: Icom Scope windows renewed
  • New: IC-9700 support, includin control and & scope
  • New: Avery 4738 (70 mm x 50,8 mm auf DIN A4 2 x 5)
  • New: FT4 (MFSK sub mode)
  • New: Support Red Pitaya (Stemlab) FT8 Skimmer
  • New: Ontario QSO Party
  • New: AGCW DL VHF/UHF Contest
  • New: IARU Region 1 6m/4m Contest
N1JM
Re: RUMlogNG version 4.3
Unread post by N1JM »
The new scope is okay. I liked the old one better except the variable waterfall height is nice. If I reduce the height to zero it crashes RunlogNG.
TNX for the hint.
What was better with the old scope?
Re: RUMlogNG version 4.3.2
RUMlog 4.3.2 is ready for download: http://dl2rum.de/RUMlogNG/RUMlogNG.zip
or in the App Store: https://itunes.apple.com/app/rumlogng/id964454561?mt=12
  • Fix: Crash when minimizing the waterfall in the Icom Scope Window - Tnx John, N1JM
  • Fix: Crash when using Fldigi 4.1.05 - Tnx Jens, DL7AUO
  • Fix: Failure in the ADIF import, when using non ASCII characters - Tnx Yuzo, JR1GDY
  • Fix: Wrong usage of WSJT-X qso data for some configurations - Tnx Pavol, OM0WT
  • New: Grid Squares added to the Contest Cheat Database (ca. 24.000 entries) - Please reload: Menu-->Online
  • New: Washington State Salmon Run
M0CLH
Unread post by M0CLH »
Since v4.3, the scope options on the 7610 revert to 'fixed' and 'Edge1' every time I change bands. I generally prefer to work with 'Centre' and a particular range - it is a bit of a nuisance to have to change it each time. Could the preferences be set per band or just kept as last set?
Also, in the 'Paper QSL in...' menu item, would it be possible to add the transmitted signal report as at the moment you have to go to the main log which involves a number of steps when manually filling in a paper card.
73 de Terry, M0CLH
Select the Centre mode once in the trx control panel, this should fix your problem.
Doesn't make sense for me. Maybe in the QSL out window?
R1WBF
Unread post by R1WBF »
DL2RUM wrote: ↑Mon 15. Jul 2019, 15:28 I generally prefer to work with 'Centre'
GD. Not helping mine IC-7300. If you change the range, it is still returned 'fixed'
Terry and me continued the trouble shooting directly. We find the solution and this will become available with the next update.
