RumLogNG FT8 and IoS 10.10.5
KJ6RGX
Unread post by KJ6RGX »
Is there a version of RUmLogNG that runs under IoS 10.10 and allows FT8 for mode? I ask because my iMac is a mid-2007 model and cannot be upgraded beyond 10.10.5 and my version of RumLogNG 1.2.6(58) does not recognize mode FT8. My iMac has been down for over a year and I just recently replaced the power supply and brought it back to life and I am in the process of updating software that will still run under 10.10.5.
Re: RumLogNG FT8 and IoS 10.10.5
Download the attached text file and copy it to: ~/Library/Containers/de.dl2rum.RUMlogNG/Data/Library/Application Support/de.dl2rum.RUMlogNG/
Modes&Submodes.txt
(932 Bytes) Downloaded 624 times
Modes&Submodes.txt
KJ6RGX
Thank you.
KJ6RGX
Well it was working but now I get this when attempting to upload LoTW -- any idea what causes this?
Do you use the latest tqsl version 2.4 and the latest configuration data 11.5?
Otherwise, there was a bug in an older RUMlog version causing this. You can e-mail me your logbook file, maybe I can repair it.
KJ6RGX
Ok, installing new TQSL version and config and will see how it goes...
KJ6RGX
Well after installing 2.4 and 11.5 updates TQSL now reports no certificate. I have requested a new certificate. Hope that gets me up and running with RumLogNG.
KJ6RGX
New certificate installed and RumLog is able to connect to LoTW again. Thanks for your help.
