RUMlogNG + WSJT-X + Kenwood TS570D - band change not working
themusicman
Unread post by themusicman »
Hi All
Wonder if someone here can offer advice on how I might resolve the following issue please.
I have RUMlogNG working almost perfectly with WSJT-X on my Kenwood TS570D. The only issue I have is that the Band Change drop down does not cause the Kenwood TS570D to change band, but if I change band and/or frequency using the VFO on the Kenwood the drop down and indicated frequency in WSJT-X does change. It appears there is only a one way communication exchange with RUMlogNG.
The sequence I get it all to run is as follows;
1 - Launch Kenwood
2 - Launch RUMlogNG - CAT control is then successfully established
3 - Launch WSJT-X - successfully launches and starts tracking on the indicated frequency/band
I have set up the WSJT-X data port in RUMlogNG prefs as 2237 which is as it should be, so I have no idea why changing the band in WSJT-X does not get passed through to RUMlogNG.
Can anyone offer advice for me please?
Many thanks.
Re: RUMlogNG + WSJT-X + Kenwood TS570D - band change not wor
Can you control mode and frequency from RL to the tx?
themusicman
DL2RUM wrote:Can you control mode and frequency from RL to the tx?
Hi
Yep, this all works fine. When I change the frequency in RUMLogNG the rig changes accordingly. I can manage DX clusters, bands, and all regular CAT control stuff from RL to the rig.
Pse post a screen shot of your RL TRX and UDP settings and from WSJT-X the Radio settings.
themusicman
Of course, no probs. Thanks so much for helping me on this.
Hope these are the images you wanted to see. The image from WSJT-X shows TEST PTT as red becasue as I took the screenshot, WSJT-X was transmitting on FT8 :D
  • You have set two options for PTT: in WSJT-X and in RUMlog. You should use one option only.
  • You have set Power up line RTS. This will disable the RTS flow control.
  • In WSJT you should select Fake it for Split operation. This is not the problem, but strongly recommended.
themusicman
I use a serial device connected to the RS232 port on the Kenwood for CAT control from the rig to Mac, and that uses CAT to control the PTT. WSJT-X uses a separate cable (from a different port) specifically for the Kenwood 570D, which takes the audio and mic from the Kenwood out to two 3.5mm connectors, and also uses a USB device to control PTT - hence CAT for PTT in RUMlogNG and RTS for PTT in WSJTX.
I had to use this because the Kenwood was using the microphone for the source audio in WSJT-X and there was no way to change that.
Not sure what to do here?
OK, again, not sure what I should do here. I use this for the reason mentioned above in 1st point.
OK, I shall amend that setting.
Disable PTT in WSJt-X or in RL Preferences-->UDP-->WSJT-X--Switch PTT
Disable the option Power up RTS line.
themusicman
I can't see an option to disable PTT in WSJT-X, but I have now disabled PTT in RL.
Still no joy on the band change drop down in WSJT-X though! When I select an alternate band,it displays the band in WSJT-X for a second, nothing happens on the rig, then WSJT-X drop down reverts to where it was before.
Guess I am going to have to live with it.
The split setting is in the r/h upper corner of the Radio panel.
