RUMlogNG version 3.7
RUMlogNG 3.7 is available here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip
See the Help files how to use the new features.
RUMlog requires now macOS 10.11 (El Capitan)
Tnx a lot Jeff, VA2SS and Georg, DJ6GI for the very valuable feedback during the the WSJT-X integration.
  • Fixed: IOTA color coding in the dx spot window - Tnx Thomas, DL1AMQ
  • Fixed: Contest interface - shown report (rx+tx) was sometimes different from the saved report Tnx Radek, OK2VBZ
  • New: Hamqth/qrz.com side panel added to the contest window
  • New: Interface to WSJT-X
  • New: Store audio, graphic or text data in your log database.
  • New: Changes for ADIF 3.0.6 (new modes and submodes, support for the tag <DARC_DOK>
  • New: SSA Monthly Contest
  • New: South America Sprint Contest
EA3HOE
Re: RUMlogNG version 3.7
Unread post by EA3HOE »
Great work on the WSJT-X integration, Tom!!
Funny how this board doesn't have the ability to delete your own account. :shock:
AA6OC
Unread post by AA6OC »
I installed the newest version, and am getting HamQTH parsing errors - screenshot attached
Seems to be a server side error, see here: https://www.hamqth.com
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at petr@ok2cqr.com to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Apache/2.4.16 (Ubuntu) Server at http://www.hamqth.com Port 443
Don't blame RUMlog. ;-)
AA6OC
With all the great work you do on this software, I would never blame you Tom! Just wanted to advise of the error message - it's a relief to know that the problem is on the hamqth side!
73 and Aloha,
Bob KH6BE
AA6OC
I am seeing a parsing error box now related to qrz.com - the QRZ site seems to be working, but maybe not the raw data feed RumLog uses?
I experienced just the same. Seems to be an minor inconvenience (or bug :-( ) in RUMlog.
When you query hamqth.com and you toggle to qrz.com before the query times out, the following Hamqth.com error states qrz.com error.
Just disregard.
From https://www.hamqth.com:
HamQTH is down ;-(
I'm sorry but it seems we lost the data. Three from four disks are broken, even RAID array controler is failing. Unfortunately I did a mistake in backup plan, backups are broken as well.
We are trying to recever the data and it will take time. In the meantime, use another free callsign database - QRZCQ
a45wg
Unread post by a45wg »
Can we please have a "disable HamQTH Option" ?
Sorry but this is extremely annoying to keep popping up all the time.
I realize it is not your fault - but we need to move on.....
Best regards
Tim, A45WG
Just keep the result drawer window closed.
You can disable the queries just by removing your user name and your password from the Preferences.
BTW, HamQTH.com is working again since few days.
