I am trying to use "Automatic change scope edges selection for the IC-7300"
In RumLogNG IC-7300 control I have checked "Set fixed edges according frequency"
My band edges are:
3.5 to 3.599
3.6 to 3.799
3.8 to 4.0
When I have the "Set fixed edges according to frequency" checked it automatically jumps to Edge 3. My radio freq. is set to 3.576, but it still jumps to Edge 3. If I click on Band Edge 1 it'll automatically jump to Band Edge 3, even when my radio frequency is 3.576. It stays on Band Edge 3.
I cannot get it to work when tuning up and down the band.The band edges do not change as I'm tuning.
I tried this on 20 meters too.
My band edges are:
14.025 to 14.070
14.071 to 14.150
14.225 to 14.350
On 20 Meters I can use the IC-7300 control to switch between band edges (unlike when I'm on 80 meters), however it still does not change band edges. I tune up and down the band and the screen does not change band edges.
Another thing I noticed and don't know if this is correct, the "QSY" button is always highlighted in the IC-7300 control. Even when I click on a band, it goes back to QSY. ??
Am I doing something wrong or is there a setting I'm missing?
Everything else seems to be working. I can turn things on and off from the IC-7300 control. I can switch modes, change bands, freq., etc.
Rich, K0PIR
Re: Automatic change scope edges selection for the IC-7300
Do the read outs below the Edge buttons show the correct selected values?
A screen shot of your settings would be helpful.
A highlighted button in macOS means always, that this is the currently default button. Just hit the Enter key to perform its action.
- Attachments
- Scope.tiff (55.26 KiB) Viewed 6690 times
Yes, it looks like eveything is correct.
Got SD?
www.K0PIR.us
www.K0PIR.us
Seems to be a problem with the number format. Please check this and report:http://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
Oh man that's perfect. I think its all good now. Thank you!
Best 73,
Rich, K0PIR
Best 73,
Rich, K0PIR
Got SD?
www.K0PIR.us
www.K0PIR.us
Thanks Rich for the feedback. You can still use this test version until a public update is available in the next few days.
