Newby & Need Help with TS-590
arcix
Re: Newby & Need Help with TS-590
Unread post by arcix »
DL2RUM wrote:You should use the "Use CTS" option, rather than the "Set RTS line" option.
here it works just fine when either "Set RTS line" or "Use CTS" are set. It doesn't when both are unchecked.
Ulde IK2TYL
It may work, but the connection will be more reliable when you use the correct handshake option.
The "Set xxx Line" option was introduced to power external interfaces.
KD8QWH
Unread post by KD8QWH »
Thank you so much for your fantastic support. With your help I was able to get it to work. I greatly appreciate all your efforts.
God Bless
Anthony
KD8QWH
