Callsigns don't match error message
k4jh
Unread post by k4jh »
When I highlight a QSO and click HamQTH.COM lookup I get the popup window showing the lookup results, and another window pops up stating "Callsigns don't match!"
The same happens with qrz.com lookups.
I'm running 4.9 beta 3.
-jav k4jh
Re: Callsigns don't match error message
This message box is shown, when you try to add data from HamQTH.com or qrz.com to the logging mask and the call-signs are not the same.
This is to prevent adding wrong data into the log.
k4jh
DL2RUM wrote:This message box is shown, when you try to add data from HamQTH.com or qrz.com to the logging mask and the call-signs are not the same.
Well but that's the part I don't understand. For example, I have a QSO with YO8TTT, I do the search after highlighting that QSO and I get the error message, even though the call sign shown is the same?
I can't duplicate that here. What are you doing? Step by step please, or a screen shoot would be helpful.
k4jh
DL2RUM wrote:I can't duplicate that here. What are you doing? Step by step please, or a screen shoot would be helpful.
Fire up RUMlog (I have 4.9 beta 3)
Highlight a QSO
Click on QSO -> HamQTH.com lookup
First the search result window pops up, then the error message pops up.
Not sure how to paste a screenshot, I'll email it to you.
K6LE
Unread post by K6LE »
That happens to me but only when I look up a portable call.
I don't use HAMqth I use QRZ.com but if I look up HH2/HB9AMO for example I will get that cautionary message.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Rick,
qrz.com does not support portable calls. When you query for FS/DL2RUM, DL2RUM's info will be returned and most of these information may be wrong. HamQTH.com is working on it.
