RUMlogNG version 3.1
What's new?
  • Fixed: Station Info Box shows correct distance now when english units are used - Tnx KH6BE
  • Fixed: Printing 60m QSLs without a Crash now - Tnx DK5LP
  • Fixed: Scrolling in the log using the arrow keys works doesn't cause the app to crash - Tnx N9JR
  • Change: New rules for the Helvetia Contest implemented
  • Change: New rules for the NAQP implemented
  • New: A row for the QSO serial number can be shown in the log table now. These number is valid for the seen QSOs only!
  • New: QSL label format Avery 5363 (2-13/16" x 1-3/8" at US Letter, 3 x 8)
  • New: Changes made for latest microHAM firmware updates (MKII: 6.7, DKII: 3.6)
  • New: Added few Apple Script commands required for JT-Bridge, see function library
  • New: Support for 60m added in:
    • Station Info Box
    • DXCC Info Box
    • Paper QSL In Info Box
    • Paper QSL Out RIG Text
    • DXCC List and counter
    • DX cluster
Available in the App Store now: https://itunes.apple.com/app/rumlogng/id964454561?mt=12
For printing (Version 2.11 - English, ca. 25Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_english.pdf
For printing (Version 2.11 - German, ca. 26Mb): http://dl2rum.de/RUMlogNG/docs/RUMlogNG_deutsch.pdf
IV3TMM
Re: RUMlogNG version 3.1
Unread post by IV3TMM »
Hi Tom, you miss this ...
http://dl2rum.de/forum/viewtopic.php?f=10&t=917
Please update. TY.
Ciao de Francesco
IV3TMM
I don't missed that. Changes are not planned. DXCC can't be set to 0 according the ADIF specification.
va3cp
Unread post by va3cp »
Hello Tom,
First of all, Happy New Year.
Just installed 3.1 and was looking through the modes and do not see MSK144 which is part of the WSJT-X package.
Any plans to add this into the mode list? I just made a contact using MSK144 and don't see how to log it.
Thanks....
Dave, VA3CP
73, Dave, VA3CP
Hi Dave,
RUMlog allows you to log ADIF specification conform modes only, see here: http://adif.org/304/ADIF_304.htm#Mode_Enumeration
This is due to compatibility reasons.
If you want to use other than listed modes on your own risk and with unknown side effects, you can edit the file Modes&Submodes.txt. The format is simple:
Mode, submode, submode, submode, …
The file is located in your users directory: ~/Library/Containers/de.dl2rum.RUMlogNG/Data/Library/Application Support/de.dl2rum.RUMlogNG/
va3cp
Thanks Tom,
I think I will leave well enough alone.
73, Dave, VA3CP
ik5zui
Unread post by ik5zui »
I'm not able to to edit QSO on the contest window. When I try the window become "transparent".
Is it possible to fix it?
Thanks!
Senza titolo1.tiff
Senza titolo1.tiff (1.63 MiB) Viewed 7456 times
Senza titolo1.tiff
I can't see this problem here.
Please check Console for Error messages while you go into the Edit mode.
Which macOS version do you use?
M0CLH
Unread post by M0CLH »
WSJT-X 1.7/JT-Bridge 2.0.1 seem to have stopped working with this release. Fldigi is fine but no CAT control with the others. Any ideas? Running OS X 10.10.5.
Thanks, Terry, M0CLH
To clarify, it's ok from fresh boot, run RUMLogNG, initialise IC-7300, run JT-Bridge and then WSJT-X. The problem seems to arise when JT-Bridge and WSJT-X are terminated, Fldigi is used (successfully) and terminated before JT-Bridge and WSJT-X are restarted. CAT control is then lost until machine is switched off and restarted. Hope that helps.
ik5zui
DL2RUM wrote:I can't see this problem here.
Thanks for your message.
I'm using OSX 10.10.5.
Senza titolo.tiff
Senza titolo.tiff (131.13 KiB) Viewed 7410 times
Senza titolo.tiff
